Advice Needed Sat finder meter
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Any body recommend a satellite finder meter
Got a needle one and it’s not in use from long time
What are you trying to do with it, look for satellites or improve the performance of a system ?
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Look for satellites with out shouting for pic and signal on Tv
Whats your budget? I personally find the Dymco/ibrave type ones you can pick up for 40 quid pretty much useless in any sunshine as the screen is unreadable. My own favoured solution is an old satellite receiver & a tatty old tv.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Around £50 but
If the £50 range is not good enough then better to buy small used tv On Gumtree
IPTV at home, used to have a full set up of dishes for personal use but don’t bother anymore as kids need the space. In the trade part time at the moment but I am thinking of doing it full time soon
Bristol
Get on EBay and as long as you’re not in a rush you’ll get one at a fairly good price. Horizon are pretty easy to use.
Seen lots of people buying these, Labgear S201 Satellite Meter about £100 brand new so much cheaper 2nd hand
funtime261
Octagon SF8008, Vu+Duo2. ZGemma H9S, GT Combo, 1.1m offset USALS, inverto black ultra single, Gibertini OP125L , inverto black ultra single.
West Mids
As mentioned above I also use one of these....cheap as chips and great bit of kit. Does all I need, shows the TV channels live and will drive my motor too.
Mine's called the iBraveBox but it is badged as as other models but they all look and do the same.
Those ibravebox / dymaco boxes are totally useless on any day with a reasonable amount of sunlight - you cant read the screen if there is any glare at all.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
The ibrave ones are also a gtmedia clone.
Put that pervy Macintosh of yours to use, if the existing screen cover isn't up to the job.
