Advice Needed Sx88+
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Hi
Just received a delivery of my sx88+
I am not able to change language to English
It’s in German
When I turned it on all I can see the following
Tap the "EXIT" key on the remote control several times until you come right out to the main screen - then tap the "MENU" key, and use the Left/Right scroll buttons quite a few times until you come to the "INSTALLATION" icon. "SELECT" that to take you into the various setup menus., and then look for one that allows you to select the language.
PS: did you buy the SX88+ from a UK or German supplier???
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Sold and delivered by Amazon
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Now I am here nothing here to change language
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Just found it
It’s in OSD settings
nelson_b
Contributor
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
In Fast Scan
It’s only foreign platforms is that right
nelson_b
Contributor
In Fast Scan
It appears so ... i,v only used Blind scan and individual transponder scan on mine.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
What is the best pic. Settings on sx88 thank you
nelson_b
Contributor
Is the lag on channel change normal
Hi .. Although i,v had this box for a couple of months now .. i,v only used it in a very limited way - (mainly for blind scan - because its quick and quite accurate) i,v not had time to study all the settings etc in detail ... there are others here on the forum who can advise you much better than me about its general use.
Mostly i use my old Dr HD - F15 receiver ...
Cheers .
Yes - one of my few "grouses" about that series of receivers (don't know about the 4k version - but that has far worse problems ATM).
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Ok thank you
The 8008 (4K) has minimal lag between channels unless you have set the video resolution to change on a per channel setting.
(or when moving between satellites)
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Really don't like the way over bright over colourful menu options one bit personally. Much prefer the dulled down version some updates ago...these various iptv services I presume none of these are free ?
