How to convert degree to kilometres
NinhTH
Satellite
Viet Nam
Hello friend,
Do you know how to convert 1 degree to kilometres in space?
Ex: one satellite orbit is 130E and another 131E so how many kilometre between two satelite? thank you
Distance of geostationary orbit to earth equator + distance from earth surface to the centre of the earth's core is your radius. Then work out diameter of a circle based on that radius, then divide by 360 for distance per degree. Of course that is distance around the circle's diameter, not in a straight line as the alien flies.
Clarke belt radius is 6378 km (earth at equator) + 35786 km (GEO altitude) = 42164 km.
Clarke belt circumference is 2 * pi * 42164 = 264924 km
1 degree on the belt is 264924 / 360 = 736 km
Note: this is the distance as measured on the belt (curved).
Distance in a straight line is
2 * 42164 * sin ( degree difference / 2 )
Nobody has mentioned Radians yet?
(Whoops, I just did, but think I might have got away with it)
Wont be accurate to more than a few kms anyway seeing as every satellite moves continually around its nominal slot.
NinhTH
Satellite
Viet Nam
Thank you so much
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Are you having plans of traveling there?
(Just curious to what you want to do with this knowledge...)
Greetz,
A33
Terryl
Custom built PC
Been there, not much going on these days.
