Stab spacers
speedy_04
VU+ Ultima 4K, gibertini op125l, Inverto Black ULTRA Single 0.2db LNB, Technomate TM-2600 M3 DiSEqC Motor
alloa
hi all i am looking for a set of stab ds-01 spacers so i can install my gibertini op125l dish onto a stab 120 hh motor. i have searched high and wide but no luck. can someone please point me in the correct direction please.
many thanks
Terryl
Custom built PC
speedy_04
alloa
What has Stab said about supplying direct from the factory ?
Terryl
Custom built PC
Have you looked here??
http://www.starsat.it/index.php?main_page=product_info&cPath=0&products_id=153&zenid=pr3h9j16q3csgp0k7m10iggtd4
Might cost more for shipping.
speedy_04
alloa
thanks for the link but the issue i have is when registering they require tax code and fiscal code of which i do not have or can enter one. They do not have the option for a guest basket as you require registration before purchase. i have contacted stab directly and waiting on a reply to place an order with them. 25 euro plus carriage not to badNew Bitmap Image.jpg
There are plenty of online fiscal code generator sites, but stick with Stab direct for a few days, it will be interesting to see if they bother replying.
speedy_04
alloa
You can try emailing Tony - he may still have some.
i did contact him but he did not have them but what he did do was instruct me on how to fix the issue. i have modified the mounting plate so it all now fits snug and works perfectly well
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
speedy_04
alloa
as requested. here are some pics of the modifications i have made and what was advised by tony. the dish comes with 2 box section brackets so if you put them one on top of each other that gives you all the clearance you need to stop the motor hitting the dish. i used an old mounting plate from an older dish and bolted it to the gibertini mounting plate which acts like a schim to allow it to tighten to the motor stub. but also changing to a stab 120 hh motor also helped out. now get 50E to 30W with very good results
a33
XSAT410
Rebox RE-9000
The Netherlands
Ah yes!
I was thinking about a solution like that. If the bolts are long enough, much is possible!
Didn't know you had the parts that made it possible already there... :)
Greetz,
A33
speedy_04
alloa
i wondered why they sent out 2 box sections. but trust me it did not show this in the instructions when building the dish. you still need some kind of schim or wedge to as the polar mount is min 55mm. with that plate and the fact that the stab motor has a 53mm stub made it possible to setup without the stab spacers but i still think the spacers would be required if using a technomate tm-2600 or dark motor
Your profile confirms you have had a dark motor previously, so what was the shaft diameter ?
Since the o/p hasn't been back on since finding a solution, here are the dimensions of each design.
Swopping the Dark motor for the Stab may have been a false economy.
And a visual end to end.
speedy_04
alloa
the issue i had with the dark motor was an communication with my vu ultima 4k hence why i changed back to the technomate tm-2600. i know that some of the led motors which i have has issues with enigma 2 boxes. when i checked the stubs there is a small difference in the diameter. but i was advised to go for the stab motor from the place i purchased the dish from
