Anyone tried to make BIG dish at home?
midozalouk
1.8 meter stb
cairo
What about using like 3 dishes and connect the lnbs to the same wire
Instead of making pipes
Or even connect them with disec
Sorry if it seems stupid idea
If it was as easy as that then we'd all be doing it. You'd need to combine the signals in such a way that the timing of the signal from each dish was perfectly identical, and that is way beyond the abilities of us hobbyists :)
midozalouk
1.8 meter stb
cairo
What about using 2 large offset feed dishes
And using the georgian or cassegrian design to project it to LNB
Would that allows us to receive out of horizon satellite
Something like that
No, same reasons as post #542. What does "out of horizon" mean?
midozalouk
1.8 meter stb
cairo
But it isn't the same sir?
I will using 2 satellite dishes to project to Single LNB at the same time? Out of horizon mean out of reception area or out of foot print
davemurgtroyd
Oxford
Oxford
It is the same reaason -distance signal travels from reflecting surfaces (dishes) would have to be identical to the micron or signals would be out of phase (and time lagged)
It is the same, the timing of the two signals when they reach the LNB will be ever so slightly different. It doesn't matter if the signals are being joined at the LNB or in a cable, if they aren't perfectly in sync there won't be any benefit, if anything there will be losses as the signals cancel each other out. Feel free to create such a set up, I'd love to be proved wrong.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Timing/distancing ("in phase") is one thing, another thing (I think even more important) is the feedhorn I guess.
A feedhorn expects an 'equal' field of signal, so to say, preferably with the highest density in the center.
So if you create more parabolic surface (by combining several offset dishes), but with holes in it; then from the holes you receive noise. (Unless you have a feedhorn with a shape, that matches the exact illumination by the parabolas.)
Adding a secondary mirror (cassegrain or gregorian) doesn't alter that.
So the effect is that you get more signal, AND more noise. So the S/N ratio result will likely be about the same as with just one offset dish, or maybe even worse.
When you want a bigger dish surface: Buy/make a bigger dish! All other solutions are troublesome, or maybe even worse....
Greetz,
A33
One of our forum members has a clover - 4 leaf - design dish, they use the image as their avatar.
Lexzie
TBS 5925 USB-tuner
The Netherlands
You forgot to mention that it gave no better results than one dish.
