Manikm909
Small'ish Dish Man
- Sep 10, 2020
- Age
- 47
- Channel Master 1.8M on Edision MIO 4K & GTMEDIA Combo, and CM1.2M on Octagon SF8008
- Kent, UK
hey guys
finally signed up to this site, should have done years ago.
been a member of many other sat sites since 2004 - but i always find this one to be most techincal and useful.
i have a gibertini 1m dish, which is a decent dish, i also have a triax td110 - not sure if i'd get better gains with that one or not....its in storage...so my first question - does anyone know if the gibby 1m is better than the Triax Td110.
second question, do i sell both, and plump for the the gibertini 1.25 or the LAMINAS 120CM OFC ....? the current setup \ dish is mounted above gutter line on a kitchen extension (TM 2600 motor) - so not too high up, and i have decent access to it for swapping \ fiddling about.
will i see much gain from going from decent 1m dishes to a decent 1.2?
i only want to go down the diseq motor route - nothing else, and i appreciate the weight factor, but i've read of people using these two 1.2m dishes on DSQ motors without issue, even i have to replace motors every 3 years or so, there so cheap, i dont mind replacing motors from time to time....
opinions pls!!!
thank you in advance.
opinions pls!!!
