Manikm909
Small'ish Dish Man
- Sep 10, 2020
- Age
- 47
- Channel Master 1.8M on Edision MIO 4K & GTMEDIA Combo, and CM1.2M on Octagon SF8008
- Kent, UK
Hi Guys
Received a Dark motor yesterday and having problems tracking the ARC - I didn't have too much time to spend on it, before bad lighting stopped play.
On the Dark motor bracket, the scale has Latitude on both sides (as opposed to latitude on one side, and elevation on the other (like a TM-2600)) - in the manual it has a table, latitude -> elevation.
It says if your latitude is 51 - elevation angle is 39 - but i think this is incorrect - it certainly didn't track the ARC for me on this setting.
Am i supposed to set the bracket \ motor at 51 to match my actual latitude - this would match what is embossed into the motor mount....
Thanks!
ManikM
Thanks!
ManikM
