Advice Needed Ku feed bracket for c band dish?
aceb
Prof Tuner 7301 /
Sussex
I'm thinking of selling my 1.8 Precision but before I do I want to try it on Ku Band, I've got an Inverto C120 LNB and adjustable feed but need the bracket to hold it in place. Before I buy this does anyone know of a UK seller? Ku LNB bracket for C band Prime Focus dish.
I wouldn't use one of those, nor a feed other than a Precision with matching aperture.
Give me until the end of the week to find an appropriate feed from the pile, I doubt I have feedarms for the 1.8m but I'm sure you can make those up.
aceb
Prof Tuner 7301 /
Sussex
Thanks CH, I do have some suitable tubing to make up some feedarms so I'll be in touch!
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Perhaps you do not need to change the bracket but just use ring spacer (the black thing in the bracket)? I could make you such a spacer.
Satfaca
Melmac (46N, 14.5E)
Melmac
I got such one from RimaNTSS, nicely made and very robust. :Y
