Forum upgraded to xenforo 2.2
chris
TalkTalk TV
Worksop UK
Just to give you a heads up that I've just updated the forum software to v2.2, please let me know if you spot any bugs or share any new features you spot.
guinea pigs kiss GIF
I like the way threads slide into view as you scroll down. But then I'm easy to please :D
Hi Chris
All my channel lists are now hidden I can see them in edit but nobody else can :eek:
I have checked though & all my channel list attachments are now hidden form view, I can see them in edit but nobody else can,
This latest upgrade may have done this to other attachments loaded by members here that are now invisible to everyone else :(
chris
TalkTalk TV
Worksop UK
What type of attachments are they gif jpeg pdf ?
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
seems ok, but i think i will avoid the sliding threads when ive had a beer or two :-ohmy
It looks very smart Chris, but Im not very keen on the bottom threads sliding into view. Which just goes to show you cant please all the people all the time as 2 folks have said they like it. :-rofl2
I will get used to it but its a bit of a shock to the system :D
Sorry, don't like this at all. First off it doesn't render without javascript, which means it slurps much more data when on a mobile connection.
Secondly the top menu bar is hidden by an advert which makes it inaccessible on a mobile.
Please can we have the option to use the previous skin? On a mobile it's not a nice experience at all now.
jpeg
The login screen on a mobile is mostly covered by adverts too :N
The animations on a small screen are extremely off putting and need to go :N
The way the smilie/emojis are hidden away in the reply box :N
And finally, to quote Yorkshire News from Soccer AM (from when Soccer AM was actually watchable), "change is not good".
User image on the top menu bar is skewed.
Not a good upgrade Chris can we go back to the previous version until you can fix all these issues :confused
Ah I see that Chris has gone offline now maybe he will fix it when he comes back ?
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
The pdf I added in the first post here is also gone:
The "pictures" in the text appear normally, though.
Greetz,
A33
Ah, that would explain why I'm now being bothered by a message at the top of the thread (and taking up valuable screen space) about updating my browser. Can't see these sliding messages - which is probably a good thing.
The program is still a system hog and demands a lot of processor cycles. A shame it can't be lean like phpBB.
And can I whinge that I still can't use Alt+S keyboard shortcut to make a post.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
These fellas spring to mind :-mamster:-smallmam no issues for me so far (famous last words)
Good to see the thread title capitalisation error bug has been fixed :)
Attachments in the links in William-1's first post are now showing:Y
Ctrl+Enter works
