Visiblewave Hybrid Wideband/universal Quad LNB
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
hi,
i am intersted to know how this fully packed LNB performs against inverto ....etc
any pro experiences or comments ??
Fitted a couple, they work Ok.
Presumably the feed horn is optimised for a non-flat oval Sky minidish, with a 37mm neck also.
What reason are you fitting them for, if not for Q /HD / freesat reception in this country ?
pipino
Back from the dead
For dScr distribution in fringe areas like in spain with legacy output option ..as far as i know its the only hybrid LNB in the market
Surely most later dSCR switches accept a wideband input and then provide legacy as well as SCR output?
