- UK
Then it will be the feed that is on the wideband LNB being completely incompatible with the dish design.
You could cut it off and fit another feed horn, my guess is it is better to send everything back to Sky for a full unequivocal refund, flog off the MaxView components , then look out for a Sky HD system you can buy outright.
