- Mar 29, 2004
- UK
I wish to get dual polarity Ku-Band Rx on a Prodelin 1244 antenna that has the 39 degree Ku feedhorn attached to a Prodelin Rx/Tx orthomode.
Is the simplest option to remove the Prodelin Rx/Tx orthomode from the 39 degree feedhorn and replace it with a C120 LNB after drilling some aligned bolt holes at the join?
