- Mar 29, 2004
- UK
Hi @moonbase.
Could you make some measurement of your support.
I have tried to make some similar but, i do not know how good are my estimation in reality.
Thank you.
The feed assembly and support system are now installed on the Prodelin 1244 dish which is mounted on a 2.2m high pole. It is not easy to get access to it for measuring.
If there is an opportunity in the future to take some measurements I will post them in this topic.
Prodelin are usually quite good with specification drawings, there might be something for the Ku-Band feed assembly online?
