6,0° East WGS 1
dreamsat
germany
my current scan
regards dreamsat
dreamsat
germany
20243 LHCP 21300 2/3 "Data"
regards dreamsat
I was looking at that one earlier today, but it only locked later for me on the Triax TD88 and Inverto Saorsat LNBF - with only 2.8dB :)
Broadband downlink probably.
dreamsat
germany
20360 L 1983 3/4 DVBS2/32APSK
DR1 is on
best regards
Adam792
Cheltenham
Interesting! What’s the video resolution of this feed? I always wonder what these kind of feeds are actually for.
dreamsat
germany
Somewhere it said it was for the army. Unfortunately, I am no longer in this position.
dreamsat
germany
It also works with the "INVERTO Withe Tech" :Y
Satfaca
Melmac (46N, 14.5E)
Melmac
With a regular "universal" LNB?!
dreamsat
germany
With this and TBS 6983
Thanks dreamsat for reminding me about the use of the Soarsat Circular pol lnb's :Y - iv'e dug out of storage the one i have to get ready for putting it on the lnb changer in place of the Ext Ku 13.4 to 13.65 Ghz lnbf but unfortunatly the weather here is absolutely terrible with heavy rain. As soon as it eases i'll be changing it.
dreamsat
germany
Yes, I also like to use it just to check polarities. Otherwise I switched everything to GILAT with polar converter. Switching between the bands is much easier with the switchable crystals.:Y:cool:
Has DR1 left?
All I have are the feed(s) at 20243L/20800L.
dreamsat
germany
He transponder is there, they just don't always send and it has also become a little weaker. But it's also bad weather here.
regards
OK, thanks. Wet here too, will try again later if clearer.
dreamsat
germany
the image display works better with the pot player:Y
best regards
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Just my try on DR1 @20360 L.
Has DR1 left?
... Just checked it again at 3pm Llew - It's there but very very weak signal.
View attachment 133966View attachment 133967
Much the same here John. Not bad I suppose with the Triax 88cm. Not locking though.
Oddly, It's showing as Vertical polarity. I need to check that out.
