a33
Specialised Contributor
- Sep 24, 2009
- Age
- 63
XSAT410
Rebox RE-9000
- The Netherlands
When we bought the Gold card (HD), it came with a CAM.
However I never got it to work with the CAM on our Rebox 9000. Instead we use the card-slot, and an emulator or however it is called.
(Edit: softcam, I believe.)
In the italian text it never says you need a new card, but just that you need a new decoder.
So I'm not sure if there is just something wrong with the CAM?
I believe sometimes CAMs can need an update?
Sorry that I cannot give any clearer advice; just thinking out loud about your situation...
Greetz,
A33
Greetz,
A33
