Wanted C120 lnb and freehorn
Chr0nik
TM-9100 Linux receiver / Edision OS mini 4K / TM-2600 M3 motor / 110cm dish (34.5w to 50e) - 100cm dish (51.5e/52e/53e/60e)
Grays, Essex
That is already good. It's pretty weird because on the meter that I use to allign the dish (SatLink WS-6933), I get around 14.9db but on the sat box I get around 16.2db on a good day and 15.8db average and I get paranoid and start thinking it's not well alligned.
It must be the box rather than the dish alignment.
stephan94
Bavaria
I also think, some receivers have completely fanciful data
if I read the number of decibels given by the Hitube, I can say that my antenna
is very very well installed :lol:
Chr0nik
Grays, Essex
I definetelly think that the box is either too sensitive or just displaying fancy numbers. Checked the highest I could get from each sat and they seem too high.
MCelliotG
Thessaloniki, Greece
Probably a miscalculation in the Frontent.bb with their tuner, given the driver provides native DVB-API v5+. Does the satfinder show the same values?
stephan94
Bavaria
Yes, satfinder also gives the same value, this problem has from the start (at least 8 months) been indicated to a representative
hitube or the importer in the OATV forum but there has been no change since.
What is also dramatic is that in none of the so-called specialist journals was this problem noticed.
like the fact that when you blindscan the DisecQ does not go from A to B
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Result with 1meter motorised giby in Midlothian
I have the same meter and get the impression that on some transponders it maxes out at 14.9db and won't read any higher.
Chr0nik
Grays, Essex
Yes, I've seen that too.
Manikm909
Small'ish Dish Man
Kent, UK
nice list, was good to compare...mine beat you on a couple, but you win! :)
Chr0nik
Grays, Essex
are there any other sats that should be catchable with a 1.2m dish that is not on the list?
I've added 31.5 yesterday but not sure if there's any other satellite that can be scanned with a dish of that size.
Manikm909
Small'ish Dish Man
Kent, UK
i will let others answer that one mate...u do well on your far east satellites, is your dish high up with no obstructions
Chr0nik
Grays, Essex
Not that high but luckily not many obstructions on the east but having a hard time on the west - neighbors' extension blocks everything after 34.5w
Manikm909
Small'ish Dish Man
Kent, UK
i get that too with my Octagon SX88 4K - which equates to about 14.7db according to another E2 STB
