Advice Needed China Radio on 45W
Manikm909
Small'ish Dish Man
Kent, UK
hey guys, some of you may have seen the other thread re ARC at 53, but this matter of CR at 45w - was probably being missed due to the name of the thread, so thought id start a new one dedicated to it.
this isnt because i WANT chinese radio, more to do with the fact that i know my dish \ setup should get it, so it annoys me that i cant.
for those of you that can reach 45w - are you able to pull in china radio (Radio channels) - my ARC can go from 53e (12db) to 34.5w (20db) - i can also pick up weird BEAM type TPs on 53w and 63w - so I beleive my ARC to be good (it may not be) - however, 45w, seems to just totally elude me
another member on here, has the same, so im not alone - whats the trick...
any ideas...
pontiend
Contibruter
south yorkshire
I have no problem here in South Yorkshire getting 45 West until the leaves come onto the ash trees two gardens away in summer.Then I loose it until Autumn.China radio comes in at 11.7 dB
Today's scan.
TBS6983 100cm Dish
Manikm909
Small'ish Dish Man
Kent, UK
thank you!
that is very interesting indeed....its interesting because I can lock onto one of those TPs at 10.8 db - its the 11548.760 - V - 34281
although my receiver shows 11550 - V - 34286
however, nothing for 11604 - H - 989
very very odd!
Can your receiver actually cope with sub 1k Symbol Rate?
@manikm909
Have you tried several different receivers on the China Radio transponder to see if one specific receiver tuner type can lock it?
Also, are you blind scanning for the frequency or manually inputting the parameters?
Some receivers may have an issue with missing low SR frequencies on a blind scan but readily locking them on a manual parameter input scan.
Manikm909
Small'ish Dish Man
Kent, UK
yes, Octagon SX88 4K and Edision MIO 4K plus - both capable.
i will try a manual add later on but i have been blindscanning up until now...
With your Edision OS mio 4k+ if you do a transponder scan then stop it before it proceeds on to the channel scan, is China Radio listed as a found transponder.
Sometimes with those mio's I have noticed that they scan in a transponder but subsequently fail to lock it on a channel scan.
If you have access to an older receiver such as a Dr HD F15 or a TM-5402 it would be interesting to see if they would lock it?
Manikm909
Small'ish Dish Man
Kent, UK
i have an octagon sf8008 in the kitchen - i could grab that....im pretty sure the Octagon SX88 4K should lock it tho...
i'll test later when calm returns to the house
Manikm909
Small'ish Dish Man
Kent, UK
i guess the good news is, this confirms my ARC is indeed ok!!
Just played this game ..... 80cm dish in the rain in N.Yorks, with Edision Primo
China Radio SS 88 SQ 82
Both the SF8008 and the mio are E2 recevers and rely on the E2 blind scan plugin and the E2 manual scan.
The logic for testing with a receiver such as a Dr HD F15, or TM-5402 is to try it with something that is completely non E2.
Manikm909
Small'ish Dish Man
Kent, UK
appreciate that mate, but i dont have anything non E2, other than the SX88 4K
actually i do have the older sx88 in a box ready for ebay!!!! i'll try that - just remembered.
Chr0nik
TM-9100 Linux receiver / Edision OS mini 4K / TM-2600 M3 motor / 110cm dish (34.5w to 50e) - 100cm dish (51.5e/52e/53e/60e)
Grays, Essex
I've got an Edision OS mini 4K and cannot get this one either. I was able to find the data channel on 40.5w but nothing on 45w -
Manikm909
Small'ish Dish Man
Kent, UK
I've got an Edision OS mini 4K and cannot get this one either. I was able to find the data channel on 40.5w but nothing on 45w -can u
hey mate, can you lock the TP i mentioned above....
My TM-5402 M3 used to get it with no/few problems
As did the SX88 yesterday:D
PS: looks like there are more than a few "hidden" differences between the older SX88 and the 4K version.
Manikm909
Small'ish Dish Man
Kent, UK
if it pulls in china radio, i might keep the older sx88
As Lazarus' Edision Primo can do it then the SX88 can as well.
Manikm909
Small'ish Dish Man
Kent, UK
Isnt Edision Primo and sx88 the same box under the hood?
Sat01Uk
SX88 4K
Penta 85cm
Technomate 2600 H2H
Black Inverto LNB
53E - 34.5W
East Anglia
I had the SX88 + and used to get the China Radio no problem, then upgraded to the SX88 4K and no luck on them. Also I did mention this before in another post, but was not able to get the Joy FM, Metro FM radio etc on Turksat, to the point I even emailed Lyngsat, it was tested and the radio is coming in loud and clear according to Lyngsat. These receivers seem to struggle with them low symbol rates. Am I missing the China stations?, no but as Manikm909 mentioned it’s more so I should get them but can’t. If older receivers can pick these things up why can’t the new ones!?
