Advice Needed China Radio on 45W
what happened to the PRIMO - discontinued...why?
did they have power supply issues or something...​
No. Excellent receiver with no generic hardware issues.
Manikm909
Small'ish Dish Man
Kent, UK
No idea. The current range, presumably.
The Primo remote uses the same codes as the Octagon SX88 series - and therefore operates the SF8008 as well thanks to a recent update by Octagon :(
Manikm909
Small'ish Dish Man
Kent, UK
thats the reason im looking for a second box! ideally i want my sf8008 and sx88 in lounge, but the remotes work both boxes, therefore, a disaster, - thanks - good to know the primo uses same codes - now i wont bother pursuing with that - shame there isnt a function to change the remote channel freq.
I did ask Octagon if it could be disabled but got no response. If you can downgrade to older firmware maybe you can solve your issue.
Manikm909
Small'ish Dish Man
Kent, UK
oh right, ive just posted in octagon forum - thanks, so this didnt use to be an issue then??? how long ago, if true.
Manikm909
Small'ish Dish Man
Kent, UK
thank you!
interesting this bit:
EN, Selection menu with more options & remote controls later!
I believe that's just referring to when the update was going to be available i.e. later that day
