Advice Needed Labgear PSA120 "Active Splitter" (10-2300Mhz) - any have a spec sheet?
Afternoon
Been having a look in the "junkbox" and found the above, which I think I might need to reinstall & use with VMA's SSA.
However, I think I lost the actual spec sheet several years ago and it does not now seem available to download from the Philex/Labgear website - therefore does anyone had a copy stored somewhere that they could PM to me?
If so, thanks in advance for that.
It is a wideband two way splitter - 12dB amplification , powered by either 12V or from the satellite receiver tuner.
Not a lot else to add, apart from you mentioned the same item five years ago, deaf to DiSEqC commands, which would make sense since the minimum port transfer frequency is rated at 10MHz.
Thx - I had totally forgotten about that thread!
Anyway, in a bit, I'll try it out again to see if it will now work on with DiSEqC commands.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
If it doesn't pass diseqc commands, chances are that 22kHz-continuous is also not passed?
For the all ports DC pass it is not indicated, if it is unidirectional, or bi(tri!)directional.
In the latter case, power from one receiver could reach the other receiver. I'd be carefull there!
(But this you can easily measure with a multimeter.)
greetz,
A33
greetz,
A33
Thx
Not got around to a DiSEqC check yet, but a simple multimeter check proved that there is no DC path from the input to the outputs(not surprising, seeing that it has an amp of some sort inside (couldn't take a look inside - looks like the cover was soldered in place as there are no screws).
