- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
All that is required is a 'V' or wedge that has the same angle as the Channel Master reflector offset. The Superjack 1224 has a similar design option to allow operation with non prime focus dishes.He needs to increase the range of the declination angle to match the offset of the dish.
The front end of the IRTE polar mount with four bolt holes is more than adequate to hold the weight of the dish and ironmongery securely.
