RandyHuggins75
- Mar 19, 2021
- Age
- 49
- Arris FREESAT UHD-4X Smart 4K Ultra HD Digital TV Recorder - 500 GB
- Brackenll, Berkshire
Hi All,
I've just puchased a FREESAT UHD-4X Smart 4K Ultra HD Digital TV Recorder (500 GB version) to replace an old Bush Freesat HD box & have managed to get everything running fine. Signal stregnth & quality are showing as good (Using a Standard LNB with 1 cable - LNB Status shows as stable)
The only issue I am having is with regards to the BBC channels, for some reason whenever I select any of the BBC channels, the picture appears then disappears until I press the Home & then the Back buttons, where it then decides to grace my TV with its presence. All of the other channels work straight away with out any issues.
I've done a re-tune as well as a hard reset with the same result.
Has anyone else had this issue?
Thanks,
Keith.
Thanks,
Keith.
