Dr Hd F16
Costactc
Canada
I'm really pleased with the results I've had with my dr hd f15 and seriously considering ordering the f16 from Alexey. Any others out there with an f16 and what do you think of this receiver.
Costactc
Canada
Also curious as to what fw with this receiver would be best for true fta.
dxhound2003
Az Box Premium.
Triax 110 cm dish motorised.
Black Ultra LNB. Nov 2011 DrD F15.
Dundalk Ireland
Do you know that the F16 is older than the F15? From the videos on Youtube the F16 was around in 2009 and the F15 not until 2011.
Costactc
Canada
I had no idea. I really like the f15 and the f16 will compliment my tm 5402 on c band.
Pretty sure that the F16 has exactly the same tuner as the F15 - just has a fancier front panel from the looks of things.
Costactc
Canada
I've also asked Alexey for a quote on the dr hd grand receiver...just waiting on his reply before I pull the trigger.
Does the F16 reliably show db under lock like the F15?
I have a F15 as a spare in case my F16 dies, when I tried F15 once it acted in a similar way.
The readings below lock on F16 may be quite stable, or changing wildly, depending on the used modulation I think.
nelson_b
Contributor
Hi Folks
Not all F15 software versions were the same in regard to under lock accuracy - as stated by @Captain Jack in post 31 here - Ordered the F15
I too reverted back to the original software on my F15 as i didn,t like the upgraded version .. and that,s the version i still run on mine.
Regards .
This made me curious, took the F15 from the box, it boots with 121p.
And I still have zips of the firmwares from back then: 121p, 125p and 210p.
Don't remember loading a HD GUI version, probably that is the 210p one.
The F16 is on 257p. There were many later firmware versions but I recall, these were without added value for DX'ing.
