cover jaeger smr 1224
anto@
italy
I am looking for a cover for jaeger smr 1224 mine are broken while the engine is in perfect condition thank you
zorrin
Specialised contributor
France
www.facebook.com
france
If you have the original cover you may try to build a thermoforming machine.
Just need plywood, coke bottle and a vacuum.
It will be not perfect but it can do the job.
Mickha
North West
I seem to recall someone making one out of metal, sometime ago, as the Jaeger1224 were known to easily become broken, especially at certain points.
Try an internet search, as I think they also provided full instructions, and a guide.
If you can't find that, as it might have gone, check out an old Wheeler Dealers episode, where Edd China had to build a new air conditioning box, for a car, he was working on, out of metal, instead of plastic, as the method should be similar. Don't forget to sound deaden, any construction, you make, to quieten it down.
Edited to add more information.
A carton for frozen ice cream (3 or 4l) is approximately the same dimensions. Cut to approximate shape including the opening for the top mount and then pour thermosetting resin over the top.
anto@
italy
I still have the original one but it is broken in 2 pieces, someone has one of a broken engine could interest me
the self construction is a bit difficult but I could try, first I try to find a used one
thank you
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Maybe 3d print from your original?
If you have the original then I would glue together, seal off the lower edge and screw holes, then build up the interior with fibreglass resin.
anto@
italy
yes I still have the original
then I reassemble it in its 2 original parts and then put the resin inside
quite right ?
Yes, neater than putting it on the exterior.
