ZazaiSat
Gothenburg
Gothenburg
I want to know what dish size could be enough to get Intelsat 20 at 68.5°E Landmass coverage signal in Gothenburg? Have any one tried on Intelsat 20 at 68.5’E in Sweden, Denmark, Norway, Germany, Poland? Please give me some info about the possibilities ?
The info you require is on the screenshots! Although note thats the very minimum size you need.
ocean04
Vaasa
Western Finland (63N 22E)
Atleast few locks with 2.4m in Finland. Most of them are encrypted..
ZazaiSat
Gothenburg
Gothenburg
Good work...and can u check this frequency, 3930 H
DVB-S2
8PSK
25000
2/3....these channels Sony six, ten cricket, Sony ten 2, Sony ten 3?
DVB-S2
8PSK
25000
Unless you have a subscription you have no chance whatsoever of watching those.
ZazaiSat
Gothenburg
Gothenburg
No problem about subscription, I can get it easily, I have friends in India and Pakistan so no problem at all of subscription and important is ti get good signal
No one can say for certain if you will get a good signal - signal strength variations can happen over quite small distances due to minute imperfections in the transmission dish on the spacecraft. Its all educated guesswork. All you can do is buy a dish of an appropriate size and hope for the best.
ZazaiSat
Gothenburg
Gothenburg
Ok and I’m going to order one 3m Satellite Dish and does anyone know from which website I can order it?
What type of property do you own ?
Does it have a strong roof or large garden ?
Is there a clar line of site to the satellite ?
ZazaiSat
Gothenburg
Gothenburg
I’m living in a Villa/Bungalow and yes it has a good large garden and clear line of site
Do you mind digging a VERY deep hole in your garden and filling it with concrete to make a sturdy base pad for it?
ZazaiSat
Gothenburg
Gothenburg
No problem for me, I have Been wanting this from long time to fix this and I have two target satellites one is this Intelsat 20 at 68.5°E Landmass and other is GSat at 83.0°E, Tata sky so for this I’m going to buy one big dish 3m soon and Gsat 83 Tata sky is main target for me, I’m willing to pay big for it but I don’t have to much knowledge about dishes so that’s why I’m asking here at this site for help and give some info about it
I dont know the exact figures for very big dishes - one of the big dish experts should be able to give you a better idea of the amount of concrete you are going to need. Its going to be a major excavation though, expecially if the dish is a solid one. Id hazard a guess its going to be getting on for a metre cubed though. Once you have decided on the dish you need to consult some big dish experts as to the anchoring you need for it.
Instead of spending thousands of Eu on satellite gear have you considered it would be easier all round and far far cheaper to just buy one of the IPTV boxes that are stuffed full of stations from a particular area??
