- May 26, 2020
- Raven mk2 zone 2 x4, Channel Master: 90cm x3, 1.2m x2, 1.8m PF. CM polar mount x2, Az/El x3.
- South Durham
It appears the Technomate 5402 M4 is now available for £100. Specs don't look anything special - no 4K or CI+. DD+ via optical... may mean trouble for French channels on 5W. Does anyone really need an RF modulator?
Specs:
Fully MPEG-2, MPEG-4, HEVC, H.264 & H.265 Compliant
DVB-S & DVB-S2 QPSK, 8PSK, 16APSK, 32APSK Compliant
Satellite Multi-Stream supported
Output resolution: Full HD 1080p, 1080i, 720p, 576p, 576i
1x Smart Card Reader & 1x Common Interface (CI) slot
HDMI Output
Dolby Digital Plus compliant via optical S/PDIF output
20,000 TV & Radio Channel Memory
2x USB PVR Ready Ports via a USB-powered external device: Rewind/Forward, Timeshift (Pause Live TV) & Record channels. Compatible up to 1TB (not included).
Compatible media files: .3gp, .avi, .dat, .flv, .mkv, .mov, .mp4, .mpg, .m2ts, .ts, .vob, .flac, .mp2, .mp3, .ogg, .wav, .bmp, .gif, .jpg
USB compatible with WiFi & 3G Adapters (not included)
Record up to 2 channels (on the same transponder) and playback a file at the same time via USB or watch another channel on the same transponder.
RF Modulator (Ch. 21- 69), analogue. PAL-I, PAL B/G & PAL-K Compatible.
Scart Output with RGB and CVBS support
Ethernet Port
Apps: YouTube, Internet Radio, RSS
Detailed hardware Blind Search
Super sensitive tuner for very weak signals and weak transponders
Less than 1 second channel change
DiSEqC 1.0, 1.1, 1.2 & 1.3 (USALS) compatible
Fast & easy-to-use menu system
Favourite channel list
Auto Navigation system - select as many satellites as you want to search automatically
Extended EPG and programme reservation on EPG (please note, you can only receive what is broadcasted as free-to-air).
Channel Editing by: Favourites, Lock, Skip, Move & Delete
Channel sort by: All, Alphabet, Transponder
Parental, Installation & Receiver password lock
Multilingual OSD Menu: English, Arabic, Czech, Dutch, French, German, Greek, Italian, Polish, Portuguese, Romanian, Russian, Spanish, Suomi, Turkish
Multiple audio language broadcasts supported
PAL/NTSC supported
SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
4:3 & 16:9 screen formats
Timer & multi-event timer functions
Automatic FEC and PID detection and manual entry of PID values
Teletext & Subtitle supported by OSD and VBI
Loop through satellite tuner
Real time clock
LNB short-circuit protection onboard
1W Standby power consumption option
Accessories included: remote control with batteries, 1.2m HDMI Cable
Dimensions: 300x80x310 mm (wxhxd)
Specs:
HDMI Output
Ethernet Port
PAL/NTSC supported
Real time clock
http://www.technomate.com/store/products.php?product=TM%252d5402-M4
