Technomate 5402 M4
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
Wed TM sent message
We didn't want to release this new software because we found a recording issue. The engineers said it will be fixed by tomorrow
Todays update
The engineers are still working on the update as they've found an issue after testing.
They have promised to release an updated software next week but can't commit to a date other than it will be before the end of
Unlikely to be a clone, the front panel design usually determines the layout behind, (button/display/USB port), and this PCB might have the detail of the factory code
without taking the lid off again here's a couple of my stock pics enlarged of the main pcb and tuner board showing some sort of info if any use.
FWIW, taking a pure guess - from the 1st pic, the small (tuner?) PCB is coded "20180705", so I'm thinking that that board was designed around June/July 2018, if that might give any sort of "chronological" clue to anything similar of about the same vintage??
manic01
GB
I meant what was it badged from sorry.
In reality a lot of sat receivers are just "black boxes" that give no real indication of where they were designed/made.
Therefore, it is sometimes easier to deduce that when you know what is actually inside the box - and thus photos of the latter could prompt someone else's memories of what he/she has found inside their own boxes &/or what they have seen elsewhere on the web.
View attachment 136995View attachment 136996
Since people seem to be doing some "forensic" work to try to work out where this thing came from, and when, do you have any further shotos of the inside of the box (notably an overall shot of the main PCB and what is on/around it)?
For any particular view, let me know. Here's a few to go on with
Thanks for those - now to see if anyone recognises anything!
manic01
GB
Theres a new Beta patch out, seems to have sorted a few things.
manic01
GB
New patch 1.04 non beta out no, seems to have sorted the audio on server channels, added redtube (mature content), all other reported issues still outstanding but getting there now.
manic01
GB
July 5 patch sorted motor issues and few other minor issues, nearly there now, still few issues outstanding including diseqc switch settings, 7 day epg, some cam/card compatability issues etc.
Yes, turning into a good box. Tuner sensitivity is excellent!
Yep, can confirm the tuner performance-very good.
Iv'e got a few requirements i'd like to see implemented still but they are more aimed at an enthusiast type user so might be classed as a non essential task for the code writers and put on the back burner
Agree, they certainly changed the sw to delete all transponders before a blind scan as you could only do one at a time before. Not a bad box at all now..
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
GTMedia V8 UHD
GTMedia GTcombo x 2
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Valuable comments, thanks
and hopefully will generate sales.:Y
Can you provide the full tuner model number, its not fully clear from the image
