Advice Needed Accurate Cutting Tool
I'm in need of some straight cuts on a piece of HSS metal and have a good angle grinder with the appropriate diamond blade.
Has anyone got advice on the best way to hold the grinder securely against the piece of metal, I had thought of cobbling something to turn it into a hinged device, similar to a bench circular saw for wood, but if there is an easier way then I'm all ears.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Sounds like an accident waiting to happen. Too big a job for a hacksaw or jigsaw?
Reg Prescott again.
It's high carbon steel from a CAD machine, the best bimetal blades I have won't touch it.
Toying with the idea of a mitre saw base converted to fit the grinder.
TJExcalibur
Out of this world.
Southern England
Has anyone got advise on the best way to hold the grinder securely against the piece of metal, I had thought of cobbling something to turn it into a hinged device, similar to a bench circular saw for wood, but if there is an easier way then I'm all ears.
I used these for stainless steel, burn out a bit quick but do a good job.
amazon.co.uk/gp/product/B06X6J9JT5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Thanks, I already have the diamond cutting disk and a powerful 125mm grinder here, just looking for stability beyond a steady hand.
Maybe a couple of beers beforehand..
Terryl
Custom built PC
Can you replace the blade on the miter saw with the diamond disk? Or are the two of different sized shaft holes.
I have in a pinch used some plywood and two by fours to make up a base for an angle grinder, using a large heavy duty hinge, some heavy hose clamps, I made up a base of plywood with the 2x4's as the mount and handle for the grinder.
Some grinders have a mounting hole for a handle, you can also use that to help hold the grinder to the 2x4, just use the correct sized bolt to help mount the grinder.
By mitre saw I mean the large hacksaw lookalike, which comes with a locking plinth for cutting specific angles.
Yes, the grinder has a removeable handle, thanks (another idea).
Terryl
Custom built PC
This is what I made up. (something like it)
https://www.youtube.com/watch?v=wXT6TeQcA6g
