18°W
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
I think, it´s from the new Inzelsat 37e.
Probably tests...
3877 L 16195 3/5 DVB-S2 8PSK, KFS mux (ID: KFS Zambia in clear, others encrypted)
3907 L 26500 2/3 DVB-S2, mux, but black screen atm.
pride21
Sandown Isle of Wight
Hi all any one who wants to download ZBC on 4016R 4444 and the GHANA mux on4027R 9037 should do so while its a strong signal.P3060028.jpgP3060029.jpg
pride21
Hi all just tried 4010R 6730 never had hint of a signal ever got two channels at 5db TPA1 and TPA2P3060031.jpg
pride21
Hi Analoguesat the only one i can pick up is 3907L 26500 at 4.7db all blank channels.
Really? I am surprised as most of those listed are pretty strong here. The only one I am not picking up is the Mozambique mux on 4000R (7.7dB - just under lock).
BTW, I have to adjust the dish a little between R and L polarities to maximise signal on each. This is really annoying and I get this on all circular satellites :(
pride21
Hi CJ i forgot about that moved dish to the east got 3877L 26500 the only one in clear is KFS Zambia at 5.8db and its raining need a bigger dish.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Scan at 12.30hrs today shows as below...................................¿no time to check and adjust at the mo but suspect possibly that 3816 L 19086 and 4171 R 27001 may be being picked up from NSS7 at 20.0ºW?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
Great improvement with Intelsat 37e, i can for first time pick up 4032 Ghana mix.
Very bad weather thick fog
stephan94
Bavaria
This morning I found the AFN programme on 18° West
3824 R 10997 DVB-S2 QPSK 1/2
is it new ?
Is not reported anywhere.
dx qwer
Rastatt/Germany
Thank you stephan94! Also on: 3756 R 30000 2/3 DVB-S2 8PSK.
is it new ?
Not sure how long it's been there, but can see it here also
Satfaca
Melmac (46N, 14.5E)
Melmac
Can anyone get the picture from 4.016 RH , ZBC Zimbabwe? The tool is apparently still valid but only black screen...
4016 R,4443,2/3-ZBC I found it encoded.
Satfaca
Melmac (46N, 14.5E)
Melmac
Sure it is but ... as mentioned above the tool found around should still be valid. I though someone would know why... or if there's some trick...
Satfaca
Melmac (46N, 14.5E)
Melmac
BTW, I managed to lock in the Ghanaian mux on 3.990 RH
GBC_20240226215613.jpgGhana One_20240227000557.jpgKessben TV (YFM)_20240227002553.jpgMetro TV_20240227003002.jpgPent TV_20240227000403.jpg
Satfaca
Melmac (46N, 14.5E)
Melmac
And Mozambique on 4.000 RH:
