Just Sharing This WD 40 for heavy drinkers : )
Spiff
Mullion Cove Cornwall
shopingathome.com
Technomate TM-5402HD M3 C1+ Super+
Primesat VBox
2 x Actuators
Precision 1.3m Prime Focus Dish & mount.
InvertoTwin Black Pro C120
Amiko Viper4K
Primesat VBox
2 Actuators
Precision 1.5m Prime Focus Dish & mount
Titanium C1W-PLL C Band
Seven Computers : )
Two Davis Vantage Pro Weather stations
One Waldbeck Weather Station
Good morning gentlemen from a very wet Mullion Cove.
I have taken to spraying the new galvanised brackets and other bits with WD40.
The last 5 Litre just ran out.
It had lasted a while and came with a refillable spray bottle, so I did not require that part this timer.
The best price found, a lot lower than the local ScrewFix was on eBay.
Delivered by FEDEX for £23,99 : )
I hear it is good for the knees as well LOL
God Bless Spiff
The problem with WD40 is that it soon dries out and could possibly be washed off by the rain over time.
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
I look at it as being simpler than keep painting, some parts like the mast clamps are hard to paint properly.
I cover the cameras up with plastic bags and try to avoid the cables as much as possible.
Its a bit like washing and waxing the car : )
You could use wax, something like Bilt Hamber Dynax UC which sprays on.
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Just looked that one up, it has good reviews, may be when the WD40 runs out : )
Standard WD40 is a water based lubricant, so will wash off after the next downpour and needs reapplying frequently.
Better a tin of white grease and rub it all over with an old sock on the hand.
(Then you can have a go at the satellite parts :ph34r: )
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
We are so poor Channel Hopper that we wear all our old socks : )
Thought maybe grease would collect all the dust and bits from the near by trees which get evenwhere.
Well I can find lots of other uses for WD40, its handy to have and a lot more cost selective than spray cans this way.
I used to buy Isopropyl Alcohol by the gallon, originally used it for cleaning cine film, but it gradually got consumed for so many other jobs.
It has gone up a lot now so have not replaced it.
Chain wax (for motorcycles) used to be a reliable alternative, whatever was left over in the tin on the stove.
(cooled of course)
