E2 signal display in decibels?
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Hi all,
I'm considering an e2 box, one such as the SF8008. I was wondering if this or if all e2 receivers can display signal in decibels?
Also provided a receiver and app are on the same network can they connect for real time signal display?
Regards
Hi all,
Regards
Yes, most E2 images that I have used have the option to display signal levels in dB and %
If you are on the same LAN as the E2 receiver you can use the WebIf to connect to the receiver and view the signal level.
However, if you use the screen grab option of the WebIf you will need to refresh the page to update the signal level display.
There is an option to auto refresh the WebIf at an interval of your choice. You could get it to refresh every few seconds.
There is also the option to stream the E2 channels to VLC in real time apart from the initial connectivity latency.
I am not sure if this option lets you view all the menu screens in VLC as I have not tested it.
Manikm909
Small'ish Dish Man
Kent, UK
Hi all,
Regards
i have two SF-8008s - yes you can change from SNR to DB. but this is pretty standard i think in e2 - however maybe not all hardware can report on both accurately
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
How many decimal points show when using the dB value?
Can one adjust the amount of decimal points?
Manikm909
Small'ish Dish Man
Kent, UK
one decimal place....i.e 16.8db
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I thought there was a phone app. I may be thinking of the VU+ range of receivers.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Manikm909
Small'ish Dish Man
Kent, UK
yes there are a few apps which hook into E2 when on your LAN (or portforwarded on WAN)
why do you want more than one decimal place?
Interesting, which Android apps would you consider as useful and can an E2 box be fully controlled with them?
astra19
98cm motorised technomate. 50e to 34.5w
Europe
My Webif just shows a percentage under SNR, even the part that says DB.
Manikm909
Small'ish Dish Man
Kent, UK
well i use "SignalMeter" on Android - its how i align my dish when outside
it hooks into your E2 bouquet
you can do bits from it, inc screen shots etc \ signal meter etc \ change channel (and sat position)
krkadoni dot com make it
Screen grabs taken from WebIf of Edision Nino Pro E2 receiver attached below.
It shows both dB in both the signal finder menu and the channel info.
Does your Edision receiver grab those T2-MI transponders natively or do you have to pass it through astra-sm?
If you are referring to the two screen grabs I uploaded above from 53.0E in C-Band the receiver cleared the pictures without having to use astra-sm.
astra19
Europe
Must be the skin/box then, since my Vu+ Blackhole is on Openwebif and looks like this: Webif - OpenPLi Wiki
Manikm909
Small'ish Dish Man
Kent, UK
4wd
Getting the picture
5 W, 9-13-19-28 E
krkadoni app
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Not all boxes will give a proper DB value, my Gigablue and my Vu+ uno 4k se don't. I believe all boxes from these manufacturers won't.
Some skins can get around this by 'calculating' the value, and displaying it, but is not as accurate as a real DB value.
Manikm909
Small'ish Dish Man
Kent, UK
Well I think it's about .5 to 1db difference on my octagon to my tm5402 M3 . Never sure which is more accurate
MCelliotG
Thessaloniki, Greece
Hi all,
Regards
Short answer: NO!!!
Long answer: It depends exclusively on the type of tuner used in the receivers in combination with the tuner driver. Receivers with Silabs, Montage and Availink tuners can display dB natively and quite accurately. This includes brands such as Octagon SF, Edision OS series with E2, Mutant HD, Axas, new Dreamboxes etc.
On the flipside, most tuners in VU+ receivers will either not display dBs or display them incorrectly, since Vu has a weird policy to create drivers that do not allow db readings, even if they natively support it. Some Gigablue models do that too.
SF8008 is more than fine with dB.
