Manikm909
Small'ish Dish Man
- Sep 10, 2020
- Age
- 47
- Channel Master 1.8M on Edision MIO 4K & GTMEDIA Combo, and CM1.2M on Octagon SF8008
- Kent, UK
before my new actuator arrives (which i am new to by the way, never used jacks before) i would like your advice on best position to place it.
i seem to have an EXTRA plate, shown here in pic2 - i dont think this is part of original CM polar mount.
first question: what do you think its for?
second question: should i leave it on, or remove it.
third question, in the first pic you can see that the actuator is mounted to second position from the end rather than the very end - should that change? ive basically copied how it came.
i have heard that its best to put the jack on the left, instead of on the right, but then again, maybe the additional plate changes things for my setup...?
FYI - its a 12" temporary jack at the moment
any advice would be very welcome.
