Tecnomate F3 Super Patch help
michael-elise
Sky +.
80cm ISS dish with a manhattan diseq motor 1.2 and a diseqc 1.2 mp01 mini positioner motorised dish install.
Freesat panasonic G10B TV.
Hertford
Hi all,
I was wondering if someone I own an old TM-F3 Super and have had to factory reset it the other week and have now lost the (phantom) patch that was on it. Well I think it was a phantom patch. So now I can’t get into the biss menu etc. I can not find it anywhere on the internet I thought I had a copy on a disc but I only have the other TM models that I own. I like using this TM model so if anyone can point me in the right direction or has the patch they can let me have a copy it would be much appreciated.
kind regards
Michael
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
http://downloadtmsw.com/bbs/list.php?board=tmf35hd
Link coded in accordance with forum rules, hope it helps.
michael-elise
Sky +.
Hertford
Thanks Manic01 for getting back so quickly. I tried that but that’s for the F3/5 and I can’t get that to open on the F3 Super. Maybe I’m doing it wrong or that’s just for the F3/5 and not the F3 Super. I have the F3/5 also. Kind regards Michael
manic01
GB
Sorry my mistake, misread your post.
michael-elise
Sky +.
Hertford
manic01
GB
That’s okay no problem very easily done. Thanks again Michael
Factory reset should leave sw intact, go to system info and press 2004 it might show the menus again, what does it say in system info at the moment?
michael-elise
Sky +.
Hertford
Hi Manic01, just been into system settings and tried 2004 and nothing.The screen is showing
Model TM-F3 Super-P
H/W Version DK-V9.08.02
Load Version 25-05-2017 16:16:58
Build Date 02-08-2017 15:59:02
Mac Address
SN
Thanks again
Michael
manic01
GB
I think might have it in on laptop, will look tomorrow for you.
michael-elise
Sky +.
Hertford
manic01
GB
I think it's already on your STB, can't remember code to access menu, maybe 1512 not sure
michael-elise
Sky +.
Hertford
Thanks I have just tried that code but nope. I know it has disappeared as I used to access it from the Utility menu, but all that’s there now is Timers.
Thanks again
Michael
manic01
GB
menu-setting- enter 1512 you will see xcam, this is what you want
michael-elise
Sky +.
Hertford
Hi Manic01, Brilliant thank you for your help very much appreciate. Now back up and working.
kind regards
Michael
manic01
GB
