GTMedia GTCombo 4:2:2 receiver
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Thanks 'scopus'............switching the receiver on for the first time is offering to update to version:-
C20.A9.1.14
dated 12-01-2022
¿Is this the one you reflashed last night or is there a later version. you have?
Appreciated :Y
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Hi all.........................Have been using the V8 UHD and finding extremely good results and at a superb price.
My GT Combo has now arrived and would like to know what is the preferred firmware version to install following your own trials and experiences.
I have read both here and at the GTMedia forum that there are still many bugs to be looked at and hopefully sorted but I know after all these years here, we have dedicated sat enthusiasts who sort of break the mold of the 'norm' :-applause :Y :-applause
Thanks and all be safe.
LP
Here’s as good an appraisal you’re going to get from Combo owners. It really is a crap shoot on what firmware you install
https://www.freesat.cn/forum/viewtopic.php?f=55&t=25284&hilit=gt+Media+Combo+latest+firmware&start=25"
GTMEDIA COMBO - We need an urgent firmware update!!! - Page 2 - GTMEDIA Forum
stephan94
Bavaria
Another sample
This time the sensitivity .
Test at 26° east.
Comparison with the TBS 6983 card with very good sensitivity.
Here the receiver can show its strength
With three transponders which are shown with -10dB on the 6983 (no picture is shown no matter which video player)
the GT Combo 4k gets a picture on all three (OK not very nice, but still).
Two transponders that get a No lock with the TBS
are also shown without lock on the receiver, but the signal bar already shows a signal (like the X810 or F500 back then).
stephan94
Bavaria
at 42° East Türksat ,
Probe on 12015H 27500
TBS 6983 this well known "minus 10dB" when close to lock, but still not enough.
Openbox SX6 no signal
_Edision MIO4K no signal
_GTMedia V8Turbo no signal
_GTMedia GT Combo 4k signal with picture (not fluent)
other surprise
8K promo channel on 12604 V 34284 DVB S2 16APSK
the GTCombo gets a duplicated picture with correct pixel input and with soundtrack.
When you record this programme, you get a TS file.
Reading this file on the PC gives back the 8K with full normal picture.
C20.A9.1.14
dated 12-01-2022
Appreciated :Y
Yes, it was that version..
Satspot
1.2m Triax dish
Ireland
other surprise
Create an m3u playlist on a USB stick on your Combo box. Pop it into your PC. You can then view all your channels on the Combo via your PC with the Combo acting as a server using VLC in real time instead of recording these channels for viewing off line. Don't forget GT Share which works on both Apple and Android devices too
stephan94
Bavaria
a new test on 7°West Nilesat.
11333 H 27500 is marked with TBS 6983 as "No Lock".
Openbox SX6 no signal.
EdisionMIO4K no signal
OPenbox s3 mini HD signal finds programs , black screen( service not running)
GTmedia V8 Turbo , signal and find programs , picture not usable.
GTmedia GT Combo 4K signal and programs , the picture is bad but you can see it.
stephan94
Bavaria
Signal stripes with colour change ,
that is a bit nostalgic
X810; F500.
The receiver also offers us this special function
It is not as good as on the Openbox.
when the signal reaches its limits
it jumps from 16 to 40 % very quickly.
but it is not bad and you know
whether there is still a lot to do or not.
Offtensive
Midlands
Is the combo the box to beat with regards to tuner sensitivity? I don't own any GTMedia receivers, but I do have their BT03 sat meter and I am very impressed with it.
Satspot
1.2m Triax dish
Ireland
The tuner on the GT Media V8 UHD is definitely quite sensitive but the Combo has the software player that will attempt to resolve the video from the transport stream on 4.2.2 feeds, not perfectly but they are viewable.
Of course you can use the GTMEDIA GT Share utility to stream the transport stream to any reasonably spec Android or Apple device where given the correct codecs will play those 4.2.2 streams smoothly, your GT Media receiver acting as a server.
In fairness for the price you are getting a cheaply priced 4K receiver covering right up to DVB S2X so that can’t be a bad thing.
I did mention earlier you can create your own m3u playlist on a USB stick and in my case I just plug it into the board I have LibreELEC running on and it’s the perfect media client which will happily play 4.2.2 feeds in real time.
stephan94
Bavaria
Hello ,
Could you please make a comparison with screenshots to show the greater
sensitivity of the V8 UHD compared to the GTcombo 4K (as I do in my comparisons).
On my side, of all the receivers I have tried (and the number is quite large)
the GTcombo is really one of the best, and maybe the best.
I have to try in all cases ( DVB-S ; DVB-S2 ; 8PSK ; 16PSK etc....)
but for the moment I am impressed by the receiver,
so I ask to see if V8 HD is definitely better (with pictures)
Satspot
1.2m Triax dish
Ireland
Hello ,
I am not saying the GTMEDIA V8 UHD is better than the GTMEDIA Combo. What I did say is that the GTMedia V8 UHD tuner is quite sensitive for my purposes. Did you mention that you already owned a V8 UHD.
stephan94
Bavaria
I have a V8 Turbo and not a V8 UHD
Satspot
1.2m Triax dish
Ireland
Not truly knowing I doubt there’s much difference in the tuner hardware on those receivers. While you get certain specs included in their sales literature they generally don’t drill down to that level. You might get an answer on the GTMEDIA forum from users over there. Some very knowledgeable owners there may be able to assist on that one.
maxi_power
120cm motorised dishes
PT
Here with SF8008 this channel works without any problem.
stephan94
Bavaria
That's great for you, but we can't compare your reception to mine
, we are not in the same place, we have to compare from the same place
If I tell you that I receive akilli TV on 46°East without any problem, do you receive it with your SF8008 ?
to compare several receivers, you need to have the same conditions.
maxi_power
PT
Sorry,
As i had seen strong signal in last image, i thought it was a hardware problem.
stephan94
Bavaria
If in SD is ,
there is no problem with 4.2.2.
Immediately and fluently displayed
23.5 East
12678 V 4798 DVBS2 8PSK 3/4
Testcard
