Horizon HDSM USB - Latest Firmware and software
cityaerials
Installer with horizon meter support
Coventry
Hi, I'm looking for latest NL transponderlist, though I think since I need only for 6 satellites (Astra, Eutel etc)
every European list will do ??
Hi, If you can let me know which 6 satellites you require and any specific Transponders, I can create a file for you if it helps?
Teddy99
zgemma h2s dell pc
Ireland
Hi thanks for the sat list. I have a Horizin HDSM USB Meter and it has a new battery . but once the meter is showing 93% battery it shuts off and then i have to recharge the battery even though it shows 93% still in the battery .
Why is this would you know?
vma
Portugal
vma-satellite.blogspot.pt
RX: 3 motorized DiSEqC-1.2 dishes (100cm, 110cm, 120cm) + 7 regular dishes.
Main receiver: Vu+ Duo + many others & IRD
TX: Modulators for DVB-S/C/T + Dektec Modulators
Field Meter: Emitor, KWS, Kathrein, Unaohm, Promax, Spaun, Rover Instruments, ...
Portugal
There are two possible reasons for this to happen:
1) The "new" battery is not new or is a fake battery, which does not behave as the original battery.
2) The meter needs to know that the battery has been replaced and needs to carry out a measurement of the battery, in order to evaluate the charging/discharging curve, so that it can charge the battery correctly and then show the corect capacity percentage.
Most field meter use batteries, which are really a battery pack composed of a set of 18650 Lithium battery cells. These are combined in series and in parallel to reach the desired voltage (V) and capacity (mA). You can have your old battery pack rebuilt by professionals, but this is not cheap, as good 18650 cells easily cost around 5 Euro in Europe and if you need for example a 12V 4000mA pack, then you need to combine 3x 18650 in series to reach 12V and 2x three of them to get around 4000mA: this means you need 12 cells. At 5 Euro each you are looking at 60 Euro! Plus the work to assemble the new pack using the existing carging circuit from the old cell you get quickly at 80-100 Euro.
Never try to build those packs yourself, as Lithium cells are dangerous and can explode (mostly in your face).
I don't know how to calibrate the new battery on a Horizon meter. Rover Instruments/Prime Digital and their OEM's have a special function to do that.
Ultimately you can try a few charge/discharge cycles. But I doubt this will help much.
Regards,
Vitor
HV London
I've just started to using a Satlink WS 6980 meter & want t know how to show the polarisations Horizontal low or High like this - HL,HH,VL,VH
It only seems to show if the polarisation is High or Vertical. It doesn’t show if its a Horizontal High or low or if its a Vertical High or Low
Does anyone know if the meter can display this?
London
Hi, does anyone have the latest firmware for the HDSM Plus sat meter that would also have the quattro transponder list on it? Im in need of the Hotbird quattro transponder list but also need the Astra1 & 2 quattro transponder list?
go-loopy
Sky & Sky Q setups, domestic and commercial
kent
Hi, Do you happen to have a version with Sky Q transponders on it please?
HV London
London
Hi, Yes I have the latest SkyQ transponders, but I need the latest Hotbird Quattro transponders for a Quattro LNB?
Tom07
Horizon satellite and Terrestrial meter
United Kingdom
I didn't know the HDSM plus had a SkyQ list. Thats interesting.
Direct TV
In the business over 10 years, currently using a Horizon HD- S2 Meter.
Ireland
Hi cityaerials,
Would you have the latest transponder file for the HORIZON HD-S2 Meter???
Transponder list required below -
Turk-3A - 42E (H)
Turk-3A - 42E (V)
Hellasat3 - 39E (H)
Hellasat3 - 39E (V)
Astra-2E - 28.2E (H)
Astra-2E - 28.2E (V)
Astra-2F - 28.2E (H)
Astra-2F - 28.2E (V)
Sky-Q P1 28.2E (H)
Sky-Q P2 28.2E (V)
Astra-3B - 23.5E (H)
Astra-3B - 23.5E (V)
Astra-1 - 19.2E (H)
Astra-1 - 19.2E (V)
Eutel-16A - 16E (H)
Eutel-16A - 16E (V)
Hotbird 13E (H)
Hotbird 13E (V)
Eutelsat-9A - 9E (H)
Eutelsat-9A - 9E (V)
Astra-4A - 4.8E (H)
Astra-4A - 4.8E (V)
Astra4A N 4.8E (H)
Astra4A N 4.8E (V)
Thor-5 T1 - 0.8W (H)
Thor-5 T1 - 0.8W (V)
Thor-5 T2 - 0.8W (H)
Thor-5 T2 - 0.8W (V)
Thor-6 K1 - 0.8W (H)
Thor-6 K2 - 0.8W (V)
Intel 10-02 - 1W (H)
Intel 10-02 - 1W (V)
Amos-2 - 4W (H)
Amos-2 - 4W (V)
Eutelsat-5 - 5W (H)
Eutelsat-5 - 5W (V)
Hispasat - 30W (H)
Hispasat - 30W (V)
Kind regards
Terry
HV London
London
Hi, would it be possible to get the same transponder list that you sent to Direct TV but also with the latest Hotbird VH-HH-VL-HL & Astra 19E VH-HH-VL-HL transponders added to it as well please
satellitesally
we are satellite installers in Hull
east yorkshire
Hello, can anyone help me please. I need to update a HDSM USB - I tried the links on the earlier thread but doesn't work. TIA
Peyu75
Pace MSP980 Positioner x2szt
GI-S 980 2CR2CI HD PVR
Shovboxvitamin 5000HD
Lnb single Invacom SNF-031
Dish 2me 90E-43W Heavy Duty 36"
Orbitron mesh 3m
Laminas 1,8m 28E {1N 2F}
Poland
Hello
I'm looking for the latest hd s2 software
HDS2_G_21Aa-0001.zip
And for terrestrial hd T2
The manufacturer's website is not active and nothing can be downloaded, not even the drivers.
greetings
Peyu
cityaerials said:
What program do you make batch files I am making
S2_SatEdit
But I can't send the files to anyone without the program, they can't be uploaded
tugadigital
Hispasat
Worcester - uk
Hi, I was also looking for a software for my machine, because I accidentally deleted all the satellites and needed astra/hotbird/hispasat at least these
my model is the hd-s2
Peyu75
Orbitron mesh 3m
Poland
I do the lists myself, but to upload you need a program and it is very complicated. Where are you from, my friend, maybe I will be able to help.
tugadigital
Hispasat
Worcester - uk
Hi
i am Worcester WR5 ***, UK
arch845
Triax combi box, windows 10
Galway, ireland.
Hi, would it be possible to get the same transponder list that you sent to Direct TV, for Galway, ireland region. Mostly for sky 28.2 (including sky q). I have a HD-S2 meter. Can not find it anywhere. I have the grey lead that came with the meter and windows 10 on PC. Thank you. Kev
Peyu75
Orbitron mesh 3m
Poland
Tugadigital end arch845 i send you pm
starsatireland
motorised 1.2 m
Ireland
I would really appreciate if you could send me a list similar to the S2 one that you done for directtv above but for HDSM usb including the Sky q, the lists I have found so far does not have the sky q on it
cityaerials
Coventry
Hi cityaerials,
Turk-3A - 42E (H)
Turk-3A - 42E (V)
Hellasat3 - 39E (H)
Hellasat3 - 39E (V)
Sky-Q P1 28.2E (H)
Sky-Q P2 28.2E (V)
Astra-1 - 19.2E (H)
Astra-1 - 19.2E (V)
Eutel-16A - 16E (H)
Eutel-16A - 16E (V)
Hotbird 13E (H)
Hotbird 13E (V)
Astra-4A - 4.8E (H)
Astra-4A - 4.8E (V)
Astra4A N 4.8E (H)
Astra4A N 4.8E (V)
Amos-2 - 4W (H)
Amos-2 - 4W (V)
Eutelsat-5 - 5W (H)
Eutelsat-5 - 5W (V)
Hispasat - 30W (H)
Hispasat - 30W (V)
Kind regards
Terry
Hi, The last last preconfigured list I have the HD-S2 is http://meters.city-aerials.com/download/HD-S2/UK-SuperListFeb2020.zip
I am looking at a way of creating new list for the S2 but there is also the custom Tp option in the short term
cityaerials
Coventry
