Manikm909
Small'ish Dish Man
- Sep 10, 2020
- Age
- 47
- Channel Master 1.8M on Edision MIO 4K & GTMEDIA Combo, and CM1.2M on Octagon SF8008
- Kent, UK
hi guys
my 24inch jack is using 19 inches of the 24 to go from 54.9e to 45w - leaving 5 inches spare, but wouldnt want to max it, so lets say 4 inches - is there a way to calculate inches of jack per degree? or is it a matter of going to a sat marking, and then going to a sat 10 degrees away and measuring the difference?
also, on the vbox, i reset it at the start (fully retracted) so its a ZERO, at 45w its on 868 .....if i went to a satellite, like 58w for example, is it possible for the VBOX to get to 999 and then go back to ZERO, (which is 54.9 EAST ! for argument sake) as it tries to reach 58w, and then be REALLT confused - on a millenium bug level
thanks!!!
thanks!!!
