Older TBS Cards (6925 & 6983) With Windows 10 ?
Has anyone installed a TBS6925 or TBS6983 card in a Windows 10 PC?
If so, was it working correctly and which driver was used?
I have both these cards in Wndows 7 PC's and they work fine.
The TBS website for both the TBS5925 and TBS6983 card does not have a Windows 10 driver listed whereas for later cards such as the TBS6903 there is a Windows 10 driver listed.
As long as a Win 7 (or Win 8.1) installation is 64 bit, as opposed to 32 bit, then many/most Apps & drivers will still work under W10 - OTOH, if they don't then it may be possible to get them to work via W10's Troubleshooting route by trying the various "Compatibility mode" options.
stephan94
Bavaria
Hello .
My TBS6983 works without any problem with my 64 bits W10 PC
my old USB TBS 5925 too
All this with the latest drivers provided for the TBS
Satfaca
Melmac (46N, 14.5E)
Melmac
I have 6925, been using Windows 10 64bit for a couple of year.... no problem.
@stephan94
@Satfaca
Thank you for your replies with the confirmation that the cards work OK in Windows 10
The TBS website is not clear about it, some cards have a Windows 10 driver listed for download, other cards do not have a Windows 10 driver listed.
