Advice Needed Improving reception in Australia
Pauliewalnuts
Three Sats Optus D1,D2 and Intelsat19
Melbourne Australia
Hi there, i'm new to this site and am inexperinced in regards to satellite lingo.
I currently live in Melb Aus and have 2 x 1.2m Dishes to catch feeds from D1 nd D2 and a 90cm for Intelsat19 KU
I do have issues with signal quality so what setup dish size and quality would improve this?
Also would a better quality LNB help
TIA Paulie
7mdish
Milan, Italy
I have absolutely no experiences nor advices from your area, sorry. But remember that a bigger dish will always (ALWAYS!!) improve your signal largely better than a better LNB. Most modern LNBs have good quality, so you could gain very few points. Instead, switching from 1.2m to, say, 1.8m dish you will experience a very big jump!
Pauliewalnuts
Melbourne Australia
Pauliewalnuts
Melbourne Australia
Pauliewalnuts
Melbourne Australia
Even with a 1.2m dish some feeds the quality is poor
Pauliewalnuts
Melbourne Australia
Pauliewalnuts
Melbourne Australia
Yeah getting the ch's is no dramas but the feeds are different they come from racetracks, football grounds, motorsport tracks etc and some feeds work better than others, looks like i need a 2.4m to cover all bases. Thanks
astra19
98cm motorised technomate. 50e to 34.5w
Europe
Ah yes it's likely they're going to be a lot weaker. If you post specific frequencies people might be able to give slightly more scientific calculations.
Fisty McB
See my signature...
County Tyrone, N. Ireland
As a rule, outside broadcast & network feeds usually tend to be less powerful transmissions compared to those intended for direct-to-home broadcast transmissions (like Foxtel or VAST) from the same satellite and may also use transmission parameters that require a higher signal-to-noise (SNR, sometimes carrier-to-noise or CNR) level than the same broadcast transmissions. While a different LNB may help in gaining a marginal SNR increase, as mentioned by @7mdish nothing beats a bigger dish reflector when pulling in weak signals.
Terryl
Custom built PC
How old is your dish system??
And how far from the dish's to the receiver?? Anything inline with the coax coming from the LNB's, like a switch??
Pauliewalnuts
Melbourne Australia
Thanks for all the help much appreciated, going to get 2 x 2.4m dishes which will hopefully solve the issues, now the fun part of trying to get an installer to mount it onto my roof haha wish me luck!
7mdish
Milan, Italy
Which dishes you choose? Fixed or motorised?
Pauliewalnuts
Melbourne Australia
Not 100% sure yet mate, prob 2 solid fixed 2.4m dishes, i need them on my roof as i have a lot of shrub and trees on the ground so need a clear line of sight and only option is there.
7mdish
Milan, Italy
Why two? Do you need only two positions? If not, just one motorised is better I believe.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Are the lnb's skewed correctly?, a photo of them dishes and lnbs would help considerably
Old Dave
MediaStar HD-1100S Satlink WS-6908
Australia
Sorry no, i have screenshot the footprints from Sat Beams
A lot of things happening on Optus D1 & D2. You might have to rely on Intelsat 19 a bit more for a while.
Interesting that Lyngsat doesn't display any info on upcoming/potential changes, just what is there at the moment.
www.optus.com.au/about/media-centre/media-releases/2020/07/optus_set_to_launch_game_changing_new_satellite_in_2023
www.sciteq.com.au/optus-d2-decommissioning/
Tried to use Optus's Satellite Coverage maps but the plug-in isn't supported on edge and Adobe Flash Player is no longer supported on Chrome. Maybe it's because I'm not logged in but there are a lot of Optus satellite users who don't have an Optus account.
www.optus.com.au/support/answer?id=1684&typeId=2
hth,
Dave
Terryl
Custom built PC
