badr4
woodbud
motorised
leeds
Does anyone know if the footprint of the badr 4/5/6 sat has been removed from the uk.
I am struggling to get a signal on a 1.1m dish whereas I used to easily get a good signal on a 1m dish, my location is Yorkshire if anyone has recent info on this Satellite it would be greatly appreciated.
I'm a bit further north but if you can wait till Monday I'll try with a 90cm Channel Master.
PS 11996 H 27500 is the strongest transponder
SatSearcher
West Yorkshire
Getting normal signal levels here in West Yorkshire from BADR4 on my 1m dish, although 5 & 6 are out of reach here and always have been.
woodbud
motorised
leeds
thanks that would be helpful if you could try that and let me know the outcome, there seems to be a lack of information regarding the footprint of badr.
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Any chance your dish has dropped slightly. The usual drill. With your dish aimed at Badr apply a little pressure at the top of the dish towards yourself and see if the signal improves. Same happened to me a while back and a slight adjustment did the trick. I assume nothing has appeared in your line of sight since you last tuned to Badr. Summer vegetation possibly
marcouk
Vu+ Uno 4K SE, 1.2M Laminas motorised dish. Primesat 1.3 m dish
Hull UK
I find the best channel to get a reference lock on for this sat is Aghani at 11.977 V27500 3/4.
Once you have this channel locked in you can fine adjust the others.
Works for me with 1M dish in East Yorkshire.
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Same signal On badr4 in Scotland
1meter gibby
Sx88
11996 is 66%
12130 is 52%
rodscha
Good morning, a very sunny day... is it any good for Badr7 hunting?
10970 V 27500 and 11010 V 27500
both seem very attractive,exotic stuff mostly in English
How receivable is this transponder in your region? I'm in south france,I Just got them some time ago & I wonder when is the most suitable time within a day... dawn,morning;midday,dusk,night?
pontiend
Contibruter
south yorkshire
My dish is a bit out.After a lot of fiddling with the longitude settings this is what I get here in South Yorkshire.I think that they are from 26 East,
TBS 6983 100 cm Dish
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
Badr 7 signal level is good, I'll check at night if it changes. Right now the sky is overcast here.
screenshots:
10970 V.png11010 V.png20220516_113051_ALT-DVB @ BDA [ TBS 5927 USB DVB-S2 Tuner ] - Satellite.png20220516_113518_ALT-DVB @ BDA [ TBS 5927 USB DVB-S2 Tuner ] - Satellite.png
stephan94
Bavaria
Hello ,
From northern Bavaria (Germany)
with 1,80m 10 dB 10970 V
with 1,20m 7,8 dB
11010 V 27500
10,2 dB 1,80m
7,5 dB 1,20m
Encode_1080P_863.mp4_20220516_132346.728.jpgEncode_1080P_862.mp4_20220516_132421.919.jpg
10.3dB on 11996 H 27500 just now, in light drizzle & cloudy conditions. As others have indicated there doesn't appear to have been any significant change to BADR 4 signals in north UK.
nelson_b
Contributor
Hi - A blind search of 26 E using a 1.2 Channel master brings up 162 t.v. channels .. I,m 45 miles west of Leeds ...
Are there any transponders in particular that you are struggling with ?
woodbud
motorised
leeds
Thanks for the reply it was mainly Palestinian channels . I assume the 162 are badr 4&7
138 FTA channels from BADR 4 using a CM 90cm here which includes the Palestine channels.
woodbud
motorised
leeds
There is nothing regarding line of sight no obstructions trees etc, just struggling to get a lock on any badr frequency, gets all the other Sat's ok , I wondered if the signal was being knocked out by astra 2 with it being so strong, I'll try again tomorrow with a different meter
Butacas
The signal levels in my area at the frequencies 10970 V and 11010 V of Badr 7 are the same as in the morning.
woodbud
motorised
leeds
I am using a 1.1m sat dish with a 0.1 dB lnb.
I always use to get a decent signal from badr on a 1metre dish which is why I queried if the footprint had changed but obviously not looking at all your replies (*many thanks)
