GTMedia GTCombo 4:2:2 receiver
Can someone check the Springwatch feed ? Badly breaking up, jittery fluctuating signal though shows 69% when I get it, yesterday also. Probably just me :(
12726 H SR 7498
Very low signal here. No lock
SimonE
Gloucestershire, UK
OK here with no break up. MER=11dB.
SimonE
Gloucestershire, UK
16E 12734H 5000 also Springwatch. MER=11dB.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Manikm909
Small'ish Dish Man
Kent, UK
Why is this in the gtmedia forum ?
SimonE
Gloucestershire, UK
sat-tv-fan, mine is a CM 1.2m dish. I suspect they had a fault when you had trouble and by the time I checked all was well again. The dishes that the BBC use are much bigger and a slight drop in level wouldn't worry them.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Yes of course, tonight perfect at 72% but I would much prefer the signal strength in db on the GT combo
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Manikm909
Small'ish Dish Man
Kent, UK
we would all like that, its been requested on the GTMEDIA forum.
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
And the developers explained why they wouldn’t be implementing this feature. Their explanation for this decision along with all things GT Combo can me seen on their forum.
GTCombo
Are there any C-band operators on this forum using lnb / lnbf's with a LO of 5.750 experiencing 'Blind Scan' software problems.
Iv'e just gone back to using my Norsat 8000RI - 3.6 to 4.8GHz with LO of 5.75 to get an update on any new developments in the Extended C-band range and having major problems .
Used with lnb's LO's of 5.150 present no problems.
And yes-the GTCombo site/forum have been notified
GTCombo
Could be connected to the probs I was having with my Hughes Ka LNB??
Having recorded the MotoGP over the weekend, the PVR listings confirm a loss of date and time (reverting to 01/01/15) is down to not having a broadband connection.
If I turn off the network time setting in device preferences and disconnect power, any date / time is lost, suggesting there is no internal clock mechanism built in, the receiver beleives it is a mobile phone which would have a battery of some sort.
dxhound2003
Az Box Premium.
Triax 110 cm dish motorised.
Black Ultra LNB. Nov 2011 DrD F15.
Dundalk Ireland
If anyone with this receiver is online, please try this 4:2:2 feed. For RTE Ireland, big occasion in Croke Park Dublin, All Ireland Gaelic Football Semi Final, Dublin v Kerry, crowd of 80,000.
Reported by stanley_cassidy on 2022-07-10 03:24 pm
Astra 2F (28.2°E)
Frequency: 12632 - Pol: V - SR: 9600 - FEC: -
Category: Sport - Others
Transmitted in: MPEG-4 4:2:2
ℹGaelic Games/Hurling(+12644v,9600)
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Astra 2F (28.2°E)
Yeah it works, about 3 frames a second :p
Unwatchable of course, but at least you can see what is going on.
There are actually 2 feeds, clean & dirty. The clean feed is on 12644v 9600.
Mohd Sadoon
240 cm PFA - 180 cm PFA - 120 cm PFA
Coverage 14W - 125E
Oman
even with "open" systems it is not that simple.
How many years did it take for the blindscan to arrive on Enigma2.
When we asked the question, there was a "no" answer; when the developers remained polite, which was not always the case, saying that the satellite.xml was much better.
Hi guys , Stephan what is the lowest SR can looked and What is the highest SR can looked by this gt combo , what about the tuner sensitivity its good ?
Thanks a lot
stephan94
Bavaria
Thanks a lot
Hallo
here you can read all the answers to your questions
ViaHussun
150 cm offset Gibertini antenna
Inverto Premium Twin LNB
TBS 5520SE TV Card
Bursa , TURKEY
46E 11064 V 12500 8PSK 4:2:2
Trabzonspor - Sivasspor
Biss
