Ebs pro website down. where to download?
EBSpro Mobile 1.3 ( Android) HAS BEEN RELEASED-New
Fixed bug in data input handling that may cause missed parts (like transponders, profiles..)
- Better connection handling.
- Added some icons.
- Updated libraries.
- Changed target sdk to 22.
* You may need to uninstall first old version and then install this one.
EBSpro v18.0.0.3,new
18.0.0.3 (stable) [11 july 2022]
- Added an option to force 18V on profile change when diseqc1.2/usals are defined to speedup motor when is needed (This feature needs StreamReader 1.2.4.129 at least)
- Enhanced Wait dialog info for diseqc 1.2/usals switching.
- Added menu option to set B**S/DC* key in TSA context menu from Signal Analyzer (no need to blindscan first to check a known feed)
- Moved "sounds" checkbox option to main window.
- Mobile: Show LinkMargin/LinkQuality in status.
- Mobile: Refresh device selected in EBSpro Mobile if is changed locally.
- Mobile: No show BER without signal lock.
- Mobile: Faster TSA service scan and make it more reliable.
- Mobile: Always show tuner info, even without lock or transponder selected in Mobile.
- Mobile: Show service names en status.
- Mobile: Now, if you try to use SatFeeds in EBSpro Mobile it will load the last scan report transponders if is available instead.
- Mobile: Show SNR saved in database for comparison when you are adjusting the dish (for reference) in status.
- Mobile: Show CodingMode in transponder list.
- BISS2 CA ID 0x2610 detection.
- TEI counter should count only if is in ts sync.
- Fix random GOLD PLS change in SA (?)
- Some more improvements in key handling.
- Some improvements in the a/v player.
- Total rewrite of how windows form position and size are handled.
- Update: Streamreader.dll to 1.2.4.129 (thanks to crazycat)
Thanks @Cjcr :)
MrDish1
Delta Star
Qth:Aalten
No virus in it ?!
because i`ff got a massage ; virus .
Mvg
You can install EBSpro without worrying. The antivirus you are using does not recognize it because it is considered a "foreign" object, like many other applications. Rather than make a mistake, it is better to "ban" it.
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
EBSpro v18.0.0.4 New!
18.0.0.4 (stable) [16 july 2022]
- Fixed a small problem handling windows size for some users and better multi-monitor handling.
- Update: Streamreader.dll to 1.2.4.133(thanks to @CrazyCat)
