7°E Eutelsat 7
dreamsat
germany
thanks
my signal
feed army
Starsat Receiver - 110cm Dish motorized
Tunisia
Is there any feed on 7East ka band now ?
SimonE
Gloucestershire, UK
s-band
Essex
Today's scan (Gilat LNB, 1.2m offset dish)
Nothing visible in the upper transponder (21655-21770MHz approx.)
feed army
Tunisia
7East 21663 H 7200
Can anyone check please?
feed army
Tunisia
I can see the signal on CS and Combo, both capture it around 6.5 dB but no locks
Very weak here also is there anyone can lock it?
Nope. ~4.2dB for me at present.
s-band
Essex
7 East Ka Band ...
21.569H keeps popping up and then dropping, along with 21.568H
SimonE
Gloucestershire, UK
There's a feed on 21662H this evening. 7200 3/4.
21619H
2S HD.
Can't recall seeing this one, at least on this frequency. New?
21619H
2S HD.
I notice that you are using Chris Lee's driver and DVB app more and more and of course Deeptho's. For this reason, I would like to know what are the significant differences in terms of performance between the two Linux applications?
There are restrictions in the tuners that are able to be be used with updateDVB, either in a desktop (or laptop) PC or a micro computer such as the Raspberry Pi.
These tuners which I have work fine for me for DVB-S/S2 - TBS 6925 ( USB TBS 5925 in the RPi, but not the TBS 5927) and TBS 6903/6983.
I have tried my TBS 6903X, but although the card is recognised in updateDVB (shows in the adapter settings), it doesn't do a spectrum scan or blindscan.
For DVB-T/T2, TBS6220 and various DVB-T/T2 usb sticks work fine.
I have a TBS 6522 which can recognise DVB-S2X channels, but it's been removed from the PC, so I can't try it with updateDVB. Maybe later.
As Chris Lee doesn't seem to be working on the app at present, we may have to wait for any further drivers for other cards to be available. It's being maintained by others in the US Rick's Wildfeed site, so maybe other tuner cards that I don't have can be used.
Performance-wise, it's excellent with low SR TP's, for instance it readily finds Radio Immac (SR128) on 16E 21564H on a blindscan or clicking on a section of the spectrum scan (as you do with Crazyscan in Windows). Only drawback is, you can't blindscan the spectrum scan graph to find working TP's as you do with Crazyscan.
As I said, the TBS 6903X doesn't work in updateDVB, so blindscan comparisons with neumodvb using the card aren't really relevant.
User-defined LOF frequencies can be set using the Custom button (similar to EBSpro in Windows), something not yet available in neumodvb, allowing for instance KA LOFs to be entered.
dreamsat
germany
my signal
Plepkeshenkie
180 cm channel master en 150 cm prime focus dish
Holten The Netherlands
Here with 180 cm Channel Master and octagon sf8008screenshot_20220715184454.jpg
dreamsat
germany
feed at 21660 H 2400 DVBS2/8PSK 5/6
7 East Ka band ...
21.595 H. 1100. 3/4. DVB-S2. ID: TV 101. Feed or program 'URHC TV'
Ignore GTCombo 'Ku' sat ident - this is a Ka tx.
SimonE
Gloucestershire, UK
Well spotted John. Coming in fine here this morning. I'll tell Lyngsat. Also the New World mux on 21627H has left.
Ive done Lyngsat Sime, forgot to mention last night that the New World Mux had gone awol
