7mdish
- Aug 11, 2013
- CM 2.4m motorised offset dish, Viking Ku-band 2-ports motorised feed, 2 SMW LNBs, RC2000A, Dreambox DM920.
- Milan, Italy
It was exactly the issue you mentioned. We thought that adding more bolts between polarmount sleeve and pole could be enough for a stronger clamp but it was not true.Ah, yes. Any tolerance between the pole and the polarmount 'sleeve' is going to be an issue. For a 100mm post, a gap of 1mm means the possibility of up to 2% tracking error in all directions (as a comparison the 6.5" post with 1mm gap brings the error down to around 0.45%).
It was alluded to in this thread around post #14
Adapting IRTE Stand for use with 2.4m Dish
Hi all after some advice, I currently have a 2.4m CM languishing in the garage whilst waiting to purchase a polar mount/stand/king post whatnot I have the chance to purchase this stand which was previously used for a 1.8m tin foil dish ie fortec star petal Could this be adapted to take my 2.4m...www.satellites.co.uk
The later IRTE polarmount has quite a deep sleeve which is clamped around the pole top and bottom, If bolted to the correct tolerance it doesn't move at all, leaving only the actuator rose joints and polar mount bearings as candidates for tracking issues.
I hope the new stand is close to the inside diameter of the polarmount ordered, otherwise you will end up with movement unless welded shut.
The polarmount had tolerances that we could not accept to avoid big tracking errors.
As I said, probably we made a bad mistake not considering this problem in the right way, so we must stop the job thinking to a new, specifically built, 100mm pole.
Having a new pole, built on-demand by a local manufacturer, we can be sure that when we resume the installation this problem will be solved. Unfortunately we must wait until September, after summer holidays.
This is the story. I let you know. Thanks.
