gap30
technomate 90cm dish
Liverpool
facebook.com/marketplace/item/1328401161238517
Looks like a 1.2m Echostar on its original galvanised polar mount.
Amazing value at £5 collected for anyone wanting to go motorised.
Gibertini 1.2m + NPRM in Nottingham 99p start price
CM 1.2m + NPRM same seller in Nottingham 99p start price
From a cinema going by the user name.
Shame they wern't Gibby 1.5's , i'd have been over there like a shot.
I use the same 1.2 on my Ka band set up - excellent performers.
Agreed - probably replaced by a fibre link !
cwsat
Gibertini 85cm / Dragonsat 3000 motor / Inverto Black Ultra LNB
Midlands
Tempted by the Gibby but I’ve not really got a need for it.
cwsat
Midlands
Cheap 1.4m that looks in decent condition.
Unsure on the make / model.
cwsat
Midlands
1.8m Channel Master up in Leeds £100.
What looks like an original galvanised dual axis motor mount, well worth the current money..
That dish has been on Ebay a couple of times in the past..
Manikm909
Small'ish Dish Man
Kent, UK
does it include the LNB ARMS i wonder....
cwsat
Midlands
The standard arms don't often survive, same with the 2.4 receive only version. Not only are they very thin but the centre feed clamp rots in the sun and the clamping bolt threads rust.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I think it is nothing to worry about. The dish looks fresh enough. Most likely, the owner just removed feedarms and put them aside to have more space in his yard. s-l1600.jpg
cwsat
Midlands
Cannot believe how much the CM 1.2 went for.
Is it because people want to use newer motors or something?
Pretty much, the cost of polar mount, actuator, positioner and wall mount will put people off compared to a Gibertini. Also it's easier to add a multi LNB setup & probably better for Ka band than the CM.
>> "& probably better for Ka band than the CM." <<
I found that to be the case also when i did a comparison between my same model 1.2 Gibby and one of my CM 1.2's.
Manikm909
Small'ish Dish Man
Kent, UK
