Feedhorn for 120cm FIBO Gregorian Dish (Grundig 1993 model)
albimesc
Grundig FIBO Gregorian Dual-reflector 120cm
Hi all,
Sorry for the semi-obscure request, but my LNB recently broke on my Grundig FIBO Gregorian-type dish. I've managed to find a good replacement C120 LNB, but the Feedhorn looks like it has seen better days. Does anyone know if these are still available anywhere, or if there is a suitable replacement/upgrade that I could purchase?
Thanks in advance.
Regards,
Albert
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
They have not been made since the 1990s. I think you will need to hunt for a second hand one.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Is that 90cm antenna? TBH, I've found out that simple universal LNB like IBU can replace original Fibo feedhorn with flanged LNB without any problems. If you do not manage to find another feedhorn consider making a holder for universal LNB like on the attached picture. IMG_20230120_193457.jpg
Edit: I see from your profile, it is 120cm dish.
Feedhorn or just the plastic cover ?
Some of the smaller takeaway pots make a good replacement.
RimaNTSS
N-E from Riga
I am pretty sure TS meant the feedhorn itself. Most likely the moisture got inside, and the aluminum surface got some oxidation. Simple change of cover cap will not solve the situation. More radical measures should be taken.
DrCband
C-Band 2.4M, Steerable Philips 1.2M and a selection of fixed 1.2M and 1.8M Ch. Master Dishes. GT Media VX8 and Octagon SF8008
West of Ireland
Is that 90cm antenna? TBH, I've found out that simple universal LNB like IBU can replace original Fibo feedhorn with flanged LNB without any problems. If you do not manage to find another feedhorn consider making a holder for universal LNB like on the attached picture. View attachment 146983
Another version, this one made from timber.
Oxidation of aluminium will not cause issues with reception (it won't degrade the feedhorn beyond acceptable unless it is enhanced with another chemical - sodium hydroxide for example)
Satfaca
Melmac (46N, 14.5E)
Melmac
Gents,
just a slight off-topic ... I recently acquired a brand-new-like Philips 120cm.
Can anyone recognize the brand and type of the original LNB attached here?
Gents,
There are remains of a Philips logo on the LNB but it could be anything
Satfaca
Melmac (46N, 14.5E)
Melmac
Aaah, indeed, it didn't come to my mind that it could have written Philips on it.
Found something similar here...
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Ima ceno, kot bi bilo zlato.
