Sold Ka Band LNB with Feedhorn (for Turksat etc)
DrCband
C-Band 2.4M, Steerable Philips 1.2M and a selection of fixed 1.2M and 1.8M Ch. Master Dishes. GT Media VX8 and Octagon SF8008
West of Ireland
Ka Band LNB and feedhorn, 18.2GHz to 19.2GHz. I did manage to pull in some of the transmissions from Turksat; however, being in the West of Ireland they are on the very edge of reception. The label on the front has faded since this image was taken. I'd like to get €140 plus costs for this.
MrDish1
Delta Star
Qth:Aalten
is this also available for other Ka frequencies. ?!
deeptho
Europe
I am interested in this.
What would be the total price (approx.) including shipping to Belgium?
Kemanci55
Turksat 42-Astra19-eutelsat 9-Azeespace45e-36eutelsat-bulgariasat0.1e- 16 eutelsat - 80e expreas- Gigablue uhd4k enigma receiver and multifeed system
Turkiye
Alibaba da bu lnb var ama çok maliyetli bunu Türkiye de bulmak zor şimdi nakliye vs kargo ile en son fiyat ne olur
Translates to:
There is this lnb on Alibaba, but it is very costly, it is hard to find it in Turkey now what is the last price with shipping vs shipping?
This Ka lnb can be found at AliExpress, maybe at a more convenient price.
The only problem would be the shipping{?)
DrCband
West of Ireland
DrCband
West of Ireland
I'll check that out and get back to you shortly.
DrCband
West of Ireland
Indeed that is where I purchased the unit. I'm selling at a substantial mark down on what I paid.
DrCband
West of Ireland
Looks like insured tracked postage is aprox 18€. I would absorb this cost in the sale, so total 140€.
deeptho
Europe
That sounds good to me. Can you send me a private message to propose how to handle the practicalities?
Mod. Note
Owing to @DrCband 's low post count, the system might not yet have enabled PMs. If that turns out to be the case, simply post here to say so and Admin should be able to manually activate.
DrCband
West of Ireland
Mod. Note
Indeed that must be the case, I don't see the option for a PM.
Miika
MM9800S, TBS5925
Estonia
Is this LNB have only one polarisation or can it switch between polarisations using 13/18 volts? And is it for linear or circular polarisation? There is no additional information.
Tnx
Tnx
WR42 waveguides would be single polarity from memory.
Tnx
Quick sketch - with cone feed removed, observe the position of the probe within the WR42 lnb waveguide entry. To change to desired linear polarity, rotate the lnb through 90° once the cone feed with the 40mm collar has been fitted back.
dreamsat
germany
Tnx
But you should always keep in mind that this is then a linear system. For Türksat and HellasSat you need a circular. If the antenna is too small or you are on the edge of the footprint you may need to add dielectric material to the feed. Similar to the C-band, the dielectric plate for circular reception.
