Inverto Black Ultra or Inverto Premium twin LNB
cwsat
Gibertini 85cm / Dragonsat 3000 motor / Inverto Black Ultra LNB
Midlands
Found the Black Ultra noticeably stronger than the Blue PLL on certain transponders across the arc.
@FC GD compared the PLL Ultra to the DRO Black Ultra and found the PLL LNB had a higher noise floor:
cwsat
Midlands
@FCGD compared the PLL Ultra to the DRO Black Ultra and found the PLL LNB had a higher noise floor:
I have the SINL40-ULTRA.
It’s a good performer and is consistent.
I do get better results on my Golden Media GM-201 though on certain transponders on certain sats.
When I get a bigger dish I’ll do another comparison.
aimanalius
Hotbird 13 e, Dish size 8 ft
Pakistan
PLL Lnb's tested, = PLL-1 top PLL-2 bottom
What is the F/D ratio of your Dish antenna on which you have tried both of these lnbs. My dish F/D ratio is 0.75 So i guess PLL-1 with extra large feedhorn would work better for dish antenna which is not too deep? or should i go for the new PLL-2 ?
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Definitely black ultra if the antenna is motorized. If the antenna is fixed, it depends on which satellite you use the antenna for.
