42E (Turksat)
Today's scan result including pictures for a few frequencies on the Turkey beam of 42.0 East is presented below.
More to follow later.
Frequencies Locked on the Turkey Beam.
1. 11977 H, SR27500
2. 12015 H, SR27500
3. 12245 H, SR27500
42.0E_20220208_TurkeyBeam_11977H_p1.jpg 42.0E_20220208_TurkeyBeam_11977H_p2.jpg 42.0E_20220208_TurkeyBeam_11977H_p3.jpg 42.0E_20220208_TurkeyBeam_12015H_p1.jpg 42.0E_20220208_TurkeyBeam_12015H_p2.jpg 42.0E_20220208_TurkeyBeam_12015H_p3.jpg 42.0E_20220208_TurkeyBeam_12245H_p1.jpg 42.0E_20220208_TurkeyBeam_12245H_p2.jpg 42.0E_20220208_TurkeyBeam_12245H_p3.jpg
Pictures and an updated list are presented below including two more frequencies from the Turkey beam scanned in with the GTMedia Combo.
1. 11977 H, SR27500
2. 12015 H, SR27500
3. 12245 H, SR27500
4. 12336 H, SR5520 (new)
5. 12346 H, SR9600 (new)
42.0E_20220208_TurkeyBeam_12336H_p1.jpg 42.0E_20220208_TurkeyBeam_12336H_p2.jpg 42.0E_20220208_TurkeyBeam_12336H_p3.jpg 42.0E_20220208_TurkeyBeam_12346H_p1.jpg 42.0E_20220208_TurkeyBeam_12346H_p2.jpg 42.0E_20220208_TurkeyBeam_12346H_p3.jpg
There are reasonably clear skies at the moment and I managed to lock another of the Turkey beam frequencies from 42.0 East.
The new one is 12329 H with SR6666. I have attached a few pictures below of the newly locked frequency.
Updated list of frequencies locked from the Turkey Beam.
1. 11977 H, SR27500
2. 12015 H, SR27500
3. 12245 H, SR27500
4. 12329 H, SR6666 (new, today)
5. 12336 H, SR5520
6. 12346 H, SR9600
42.0E_20220209_TurkeyBeam_12329H_p1.jpg 42.0E_20220209_TurkeyBeam_12329H_p2.jpg 42.0E_20220209_TurkeyBeam_12329H_p3.jpg
1. 11977 H, SR27500
2. 12015 H, SR27500
3. 12245 H, SR27500
5. 12336 H, SR5520
6. 12346 H, SR9600
View attachment 140936 View attachment 140937 View attachment 140938
Just as a one off / off topic post MB,
I modded a modern cheap pll lnbf yesterday and knocked up a temp Precision/Elite scalar Ku feed that will slot into the front of the Cband waveguide throat and sit at the FP of the 2.2 Elite reflector and then point it all at 42east and see what i can make of these signals, if anything, up here North of Nottingham.
@John
Nice, that is an interesting little project you have there.
How are you going to secure the Ku feed in place, some type of tri-locator bracket that can use the three M8 threaded holes in the Ku feed?
More pics please once you have the final mock up...
Back to the Turkey beam from 42.0E, I think that your best chance of a signal lock may be with 11977 H, SR27500 and 12245 H, SR27500.
Based on my location, these two frequencies are stronger than any of the others I have locked. However, these beams that are fringe in the UK have some odd characteristics and your location might be different.
You should certainly detect this pair of frequencies with your Promax Ranger.
One point to consider, some of the frequencies from the West beam of 42.0E are also used by the East/Turkey beams on the opposite polarity.
As the West beam frequencies are very strong they can cause a bit of cross polarisation unless the opposite polarity has been nulled out.
Initially, I found this was interfering with fringe reception from the East/Turkey beams until I adjusted the skew more accurately.
There are a decent number of frequencies from the East beam of 42.0 East that I have locked but I will finish messing about with the Turkey beam before posting any results from the East beam.
@John
Just a layer of thick velcro around the two circular feed surfaces MB, makes for a tight but perfect fit into the orifice - every mans dream MB i'm sure you will agree.
Not going too overboard with it as it's only a temp thing just to satisfy curiosity - dish now cranked back up and connecting cables into shack for some testing. "I'll be back".
@John
How much nearer to the dish is the opening rim of the Ku feed compared to the opening rim of the polo pipe?
Depending on the dish parabolic profile it might need to be ~5mm or more closer to the dish for Ku-Band than for C-Band?
Looking forward to results from the test.
@John
To start off iv'e used 755mm FP to 5mm within throat of the Precision feed - i'll have a couple of tweaks once i get the bodge of a SMA to F adapter cable to play ball - iv'e got every SMA Male to F female adapter but not the SMA Female to F Female adapter i require..... the bodge of an adapter cable is playing up so need to sort that out now.
I managed to lock the remaining frequency from the Turkey beam that I considered as a possibility.
The new one is 12356 H with SR7100, pictures attached below
There are four other frequencies on the Turkey beam that I could not lock.
However, they are quite some way below a lock and realistically they are "no hopers"
The final tally was seven from eleven frequencies locked from the Turkey beam.
Final list of frequencies locked from the Turkey Beam.
1. 11977 H, SR27500
2. 12015 H, SR27500
3. 12245 H, SR27500
4. 12329 H, SR6666
5. 12336 H, SR5520
6. 12346 H, SR9600
7. 12356 H, SR7100 (new, today)
42.0E_20220209_TurkeyBeam_12356H_p1.jpg 42.0E_20220209_TurkeyBeam_12356H_p2.jpg 42.0E_20220209_TurkeyBeam_12356H_p3.jpg
nelson_b
Contributor
Well done on your results M.B. ... another case of North - South differences ... clear skies here today for a change so had a look here .. have tried here for Turkish beam before without success -
Managed just one lock 11977 H, SR27500 .. with the 2.4.C.M. and F15 receiver .... the Octagon SX88 Optima will not lock it ? - puzzling - as its not particularly borderline on the F15.
Managed that one as well nelson - just - on the GTCombo, with the temp Lash up on the 2.2, half way between you up North and MB down South.
Thanks Nelson.
There seems to be quite a sharp drop away in signal levels on these fringe beams as you get into the Midlands and Northern UK.
The only ones I have come across so far that might be the reverse are from the Russian satellites where I think the Northern Fringe Men may possibly have the edge?
Moving on to the East beam from 42.0E, I managed to lock 10 from 13 frequencies.
The remaining 3 frequencies that I could not lock are "no hopers".
The details and pictures are below.
East beam frequencies locked from 42.0E
01. 11012 H, SR30000
02. 11096 H, SR30000
03. 11789 H, SR20000
04. 11822 H, SR14166
05. 12054 H, SR27500
06. 12083 H, SR13750
07. 12095 H, SR4800
08. 12103 H, SR8333
09. 12209 H, SR10000
10. 12219 H, SR6500
42.0E_20220209_EastBeam_11012H_p3.jpg 42.0E_20220209_EastBeam_11096H_p2.jpg 42.0E_20220209_EastBeam_11789H_p1.jpg 42.0E_20220209_EastBeam_11822H_p1.jpg 42.0E_20220209_EastBeam_12054H_p3.jpg 42.0E_20220210_EastBeam_12083H_p3.jpg 42.0E_20220209_EastBeam_12095H_p3.jpg 42.0E_20220209_EastBeam_12103H_p3.jpg 42.0E_20220209_EastBeam_12209H_p3.jpg 42.0E_20220209_EastBeam_12219H_p3.jpg
stephan94
Bavaria
today I receive the frequency 12015 H 27500
which is on the Turkish beam with 5.8 dB
stephan94
Bavaria
a scan of my reception in H of the part where there is the Turkish beam
dreamsat
germany
12379 H 30000 QPSK 3/4 good reception today
dreamsat
germany
all east beam transponders in horizontal
dreamsat
germany
a seltem guest 12356 H 7100 from Turkey Beam
stephan94
Bavaria
Satfaca
Melmac (46N, 14.5E)
Melmac
Quite some bits on this channel.:cool:
