Advice Needed 40.5W c-band ?.
3710 L - 98% on a 2.2 Elite PF - 3980 L 40% 60% fluctuating . - North Nottinghamshire. Sorry can't give a dB reading at the moment with this rx.
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Signal for 3710 L in dB, using CrazyScan and TBS 6903 on 4.9m mesh - south-west Germany.
Would a mod/admin please consider if this topic should be moved to the C-Band section and move it if appropriate?
Yup - moved to C-band section. Ive left a redirect on the other section for a few days
mikeisyou
Feed Hunter
England
What size dish is that with @John ?
Manikm909
Small'ish Dish Man
Kent, UK
just an update on this:
4177 - V - 5416 - is the strongest TP for me (1.8m UK) - 13.3Db.
"Ve Plus" channel
Adam792
Cheltenham
What's the signal level like on the BFBS transponder, presumably aimed at the Falklands? (4132 R 22500 DVB-S2 8PSK 3/5)
I'm curious as to whether they pass the DAB feed on via this one like they do on 10°E Ku band, as it seems to duplicate some of the European content according to Flysat (as well as the stations you'd expect like BFBS Falklands, Belize, Canada, etc).
Thanks!
Thanks!
Low signal level here in the Midlands at the moment on that frequency [ 2.45pm].... only managing 6dB or so on a 2.2 PF . GTCombo / TBS 6983 CS/EBSPro detects the frequency but will not lock.
I'll try a little bit later.
Joolz
1m Astro 55°E - 63°W
Strange I have 7.7db on a slightly bent 1.8M not far from you?
Joolz
Thanks!
Did you want me to send you a TS File to look at?
I was a bit surprised myself - just checked again and it's about the same , the whole feed has been covered in snow for the last day or so and i'm wondering if iv'e got some water ingress into the works now that it's beginning to thaw. They've forcast 12° temp for Monday so looks like i'll have to give it a looking over.
Adam792
Cheltenham
