Dggrr
- Sep 2, 2006
- Age
- 69
- VU + Zero, Triax TD88, Technomate TM2600 (Plus CM 1.2 in bits behind the shed)
- SE
Looking for a V-bolt to fix a Stab HH120 motor to a pole. I have one but the other is missing.
Internal width between the legs is 3" or 76mm, straight section of leg is about 80mm. Bolt is M8.
I have a square U-bolt which would do but think the V-bolt would be better/stronger and less likely to move.
Struggling to find anything with my Google-fu
