Help Required 16APSK on TBS 6522
halliwell
galaxy
Ger
Hello,
I own a TBS 6522 and would like to lock 16APSK.
Do you have a transponder that I can/should be able to lock?
best
Halli
Hello,
best
Halli
Try 10.0E, there are a some 16APSK and 32APSK frequencies on it.
wellikan
satdx.club
Dr.HD 1000 Combo, Denys H.265, TBS 6903
GIBERTINI OP 150 S
Ireland
28,2e
feeds
halliwell
galaxy
Ger
Thanks!
I'm able to lock: 12692 v 3750 with 14dB
service id 1 name : "EDS807HD.1"
Are you sure it's 16APSK, because lock is possible with TBS6522 and sundtek USB Stick (Version 6)?
(when dish is moved, signal leaves at 9dB --> fec 2/3 at 16APSK :-))
Thanks again
cheers
